containsmachine
MAXREFDES1003: 150mA, 4-channel, LED driver, SEPIC configuration
MAXREFDES1003:150mA, 4-Channel LED Driver in SEPIC Configuration
The MAX16813 is a highly efficient, high-brightness (HB) LED driver that provides four integrated LED current-sink channels. An integrated current-mode switching controller drives a DC-DC converter that provides the necessary voltage to multiple strings of HB LEDs. The device accepts a wide 4.75V to 40V input voltage range and withstands direct automotive load-dump events. The wide input range allows powering HB LEDs for small- to medium-sized LCD displays in automotive and general lighting applications.
An internal current-mode switching DC-DC controller supports boost or single-ended primary inductor converter (SEPIC) topologies and operates in an adjustable frequency range between 200kHz and 2MHz. An integrated spread-spectrum mode helps reduce EMI. Current-mode control with programmable slope compensation provides fast response and simplifies loop compensation. An adaptive output-voltage control scheme minimizes power dissipation in the LED current-sink paths. The device has a separate p-channel drive (PGATE) pin that is used for output undervoltage protection. Whenever the output falls below the threshold, the external p-MOSFET is latched off, disconnecting the input source. Cycling the EN or the input supply is required to restart the converter.
The device consists of four identical linear current-sink channels, adjustable from 20mA to 150mA with an accuracy of ±3% using a single external resistor. Multiple channels can be connected in parallel to achieve higher current per LED string. The device also features a unique pulsed dimming control through a logic input (DIM), with minimum pulse width as low as 500ns. Protection features include output overvoltage, open-LED detection and protection, programmable shorted LED detection and protection, output undervoltage protection and detection, and overtemperature protection.
This board is not available for purchase.
An LED driver in a SEPIC configuration using the MAX16813 is demonstrated for a 24V, 600mA output application. The device can drive up to 4 channels at once.
Designed, Built, Tested
This document describes the hardware shown in Figure 1. It provides a detailed systematic technical guide to designing an LED driver in a SEPIC configuration using Maxim’s MAX16813 LED driver. The LED circuit has been built and tested, details of which follow later in this document.
Design Resources
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 02:23:22
  • A quick quiz on learning the basics of analog + resistor noise
  • Recruiting C language engineers (Beijing)
  • How to avoid WinCE application running multiple times?
  • STEVAL-MKI109V3+ Test Basics
  • dd
  • Supply PHS base station amplifier Gigatec Model: GT-2077
