太白金星
DER-24 - 15W multi-output DC-DC forward converter with synchronous rectification
DER-24 - 15W Multiple Output DC-DC Forward Converter with Synchronous Rectification
This document is an engineering report describing a DC-DC forward converter with three outputs using the DPA424R. The input voltage range is 36 to 72 VDC and provides 5V/7.5V/20V, 15W output. The power supply achieves approximately 88% efficiency through synchronous rectification. This power supply uses a coupled output inductor to provide a voltage output. This document contains power supply specifications, schematics, bill of materials, transformer documentation, printed circuit layout and performance data.
Design Files
Search Datasheet?
Forum More
Update:2025-07-01 21:35:59
  • Have you guys used ObReferenceObjectByName?
  • High score font file
  • Is anyone using SPIN3202 STSPIN32F0A? I have some questions.
  • Appeared: hr -2147221164 {Class not registered} HRESULT
  • LCD display selection
  • Disassembling a 9.9 yuan 10W energy-saving lamp, is the quality reliable?
