A fully integrated high frequency synchronous rectified step-down switch-mode converter with 2-bit VID designed for V1.0A, VCCIO, PRIMCORE, EDRAM and EOPIO for IMVP8 applications
The NB681 is a fully integrated high frequency synchronous rectified step-down switch mode converter with 2-bit VID, designed for V1.0A, VCCIO, PRIMCORE, EDRAM and EOPIO for IMVP8 applications. It provides a very compact solution to achieve 6A continuous output current and 7.5A peak output current over a wide input supply range. Based on MPS proprietary switching loss reduction technology and internal Low Ron power MOSFET, the NB681 operates with high efficiency over a wide output current load range. The adaptive constant on-time (COT) control mode provides fast transient response and simplifies loop stabilization. The DC auto-tuning loop provides good load and line regulation. The NB681 also provides a low power mode for saving power in a low power state and an ultrasonic mode to avoid audible noise. Comprehensive protection features include OC limiting, OVP, UVP and thermal shutdown. The converter requires a minimum number of external components and is available in a QFN 2x3 package. Product Features Wide 4.5V to 26V operating input range V1.0A/VCCIO/PCH/EDRAM/EOPIO compatible with IMVP8 Output adjustable by 2-bit VID Low power mode/25uA low quiescent current 6A continuous output current 7.5A peak output current Selectable ultrasonic mode Adaptive COT DC auto-tuning loop for fast transients Stable with POSCAP and ceramic cap 1% reference voltage Internal soft-start and output discharge OCL, OVP, UVP protection and thermal shutdown Latch reset by EN or power cycle
Search Datasheet?
Forum More
Update:2025-08-05 21:23:22
