Due to the prolonged lockdown caused by the pandemic, several projects were progressing slowly, and unfortunately, I was unable to participate in the Spark Program. Although I cannot participate, I will continue to add projects later.
When migrating or modifying projects, please retain the source, logo, and platform information. For learning and communication purposes only, commercial use in any form is prohibited.
This project was created out of
the initial impulse: as the weather got colder, I was worried my wife wouldn't be able to drink water promptly at work, so I quickly modified it to pretend I'm a warm-hearted man ^_-
Technical exchange group: 754881030
Disclaimer: High temperature danger! Electrical danger! Welding danger! Please wear a helmet when operating. Non-professionals should not attempt to clone or manufacture this product to avoid causing other dangers. Lichuang and I assume no responsibility for any physical injuries caused by any actions...
Power supply: PD fast charging >65W.
Functions include:
1. Mode switching (cooling or heating) Cooling mode is being adjusted.
2. Temperature setting (adjust setting temperature). 3.
Temperature calibration (correct temperature deviation).
4. Water drinking reminder (timed water drinking reminder).
5. Lighting setting (adjust mood).
6. Buzzer (reminder sound).
7. Restore default (restore default parameters).
8. IoT APP remote control (loading).
Button functions: (same as encoder)
1. Double-click the middle button to activate the menu, adjust left and right, click to save.
2. On the main page, click heating (cooling), click again to stop.
3. Long press, short press .
Update log for subsequent function additions:
December 8, 2022 1.1b
1. Added cup press limit switch (to determine if the cup has left or returned to its original position).
2. Changed the external temperature and humidity sensor from separate to independent .
3. The buzzer can be fitted with a vibrator.
4. Modified PCB appearance + adapted 3D shell. The appearance is more aggressive.
5. Adjusted to use a cheaper gate driver.
6. Maximum temperature limit 105℃; top screws changed to nylon + countersunk holes.
7. Reduced heating plate diameter; compatible housing.
Update Log:
November 25, 2022 1.1a
1. Fixed the issue of the water reminder not working.
2. Corrected the water reminder sound. Long tone changed to an alarm clock beep.
3. Added middle button to cancel and reset the water reminder.
4. Added water reminder.
Other details will be updated gradually.
Firmware download software can be found by referring to the heating platform (the only difference is choosing 8266 for burning).
Note: Since the PCB was drawn first and the schematic was drawn later, please leave a message if you find any problems. XX~~~~
