qoistoochee128
MAXREFDES150#Pocket IO PLC Development Platform
Industry 4.0 is the fourth revolution in manufacturing and process automation, which poses a huge challenge to PLC design engineers: integrating more functions into increasingly smaller packages. Increasing I/O density and smaller package sizes also bring another fundamental design challenge: inevitable power consumption issues. Systems must be more power efficient than ever before to avoid PLC overheating, especially in applications where fans and vents are not typically available. Fortunately, companies like Maxim Integrated are developing new solutions that allow their integration capabilities to shine in the changing industrial market.
characteristic
  • Two analog input channels, ±12V, 24-bit ADC
  • Two analog input channels, ±24mA, 24-bit ADC
  • Analog output channel, 0V to ±12V, 16-bit DAC
  • Eight digital input channels, 36V (max), configurable for IEC® 61131-2 input types 1, 2 and 3
  • Eight digital output channels; 640mA high-side switch or 640mA push-pull output @24V
  • Two RS-485 COM ports; half-duplex, up to 42Mbps data rate
  • Three DC motor controllers: 9V to 32V full-bridge DC motor driver, up to 2.5A peak motor current (powered by independent power supply)
  • Four IO-Link host ports with M12 female connectors
  • Fully compatible with IO-Link version 1.1
  • TEConcept IO-Link Host Stack
application
  • Factory and process automation
  • Building automation
  • Robot control
  • Quickly build prototypes of new industrial control systems
  • IO-Link sensors and actuators
MAXREFDES150# Component
  • Pocket IO: MAXREFDES150MAIN# and MAXREFDES150LED#, housed in plastic housing, with Intel Edison development module
  • Connector mounting plate - MAXREFDES150ATACH#
  • 40-pin female/female cable kits – two per set
  • USB A to micro-USB B converter
  • AC to DC (24VDC, 1A) power supply, adapter for local outlet included
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-13 03:17:27
