黄土马家
PoE powered LED lighting reference circuit
PoE-Powered LED Lighting Reference Circuit
This reference circuit powers an LED light bulb using power-over-ethernet (PoE) and control through a Bluetooth® module. The bulb can be wirelessly turned on/off and dimmed with 9 levels of brightness using Bluetooth. The circuit comprises a MAX5969A powered device (PD) controller, a MAX16832 LED driver with an integrated MOSFET, a MAX15062 synchronous step-down DC-DC converter, an 8-bit microcontroller, and a Bluetooth module. This reference design includes a schematic, PCB files, and a bill of materials.
  • Proven printed circuit board (PCB) layout
  • Proven component parts list
  • Controllable with Bluetooth or Wi-Fi® module
Block Diagram
PoE-powered LED lighting block diagram.
Applications Information
The MAX5969A receives power from the power-sourcing equipment (PSE) and provides 48V (nominal) of DC power to the MAX16832 LED driver and the MAX15062 DC-DC converter. The DC-DC converter powers the 8-bit microcontroller and the Bluetooth module. The microcontroller takes user input through the Bluetooth module and converts it to a PWM-dimming signal and feeds it to the LED driver.
The board accommodates footprints for an HM-12 BT module, a BL-600 BT module, and an ESP8266 Wi-Fi module. HM-12 control software for both Android and iOS is available. Search for “PoE LED” in the appropriate app store.
Hardware Files
Schematic
Bill of Materials (BOM)
PCB CAD files
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 13:26:06
  • Set GPIO in app
  • Using pc-lint with SI
  • How low can the charging voltage of a 24V battery be?
  • ProtelDXP2004 Getting Started and Improved
  • How can we determine whether the IC's fault output PIN can drive the transistor?
  • STM32 CAN debugging is unavailable
