MartinFowler
Step-down/inverting 3A, ±5V power supply with all-ceramic capacitor design
The 1MHz, all-ceramic capacitor design provided here uses the MAX8538 dual-synchronous buck controller to provide +5V and -5V power supplies, and has soft-start and soft-shutdown functions. One controller is configured for synchronous buck conversion, providing +5V @ 3A output, and the second buck controller is configured for flyback conversion, providing -5V @ 3A output through a 1:1 transformer.
A MAX4400 op amp with a gain of -1/2 controls the negative voltage output. The MAX8538's internal 5V VL linear regulator provides bias for the op amp . The output of an op amp with a gain of -1/2 is limited to this range and is within the common-mode limits of the error amplifier.
Buck converter control gain is: V OUT /V IN = duty cycle. The control gain of the 1:1 flyback converter is: V OUT /V IN = duty cycle/(1 - duty cycle), which increases as the duty cycle increases. For a 1:1 flyback converter, duty cycle = V OUT /(V IN + V OUT ) = 5V/(10.8V + 5V) = 0.317. Thus, additional control gain = 1/(1 - 0.317) = 1.464. The additional control gain is a factor that affects the design of the Category 3 compensation network, reducing the unity gain frequency by a factor of 1.464. The inverting gain of the operational amplifier is compensated by adjusting R23, which will not affect other circuits of the compensation network.
Figure 1.
View larger image
figure 1.
Documentation
Search Datasheet?
Forum More
Update:2025-08-10 22:22:57
