civzW0UVP
N20 motor small flashlight v2
The N20 geared motor charges the capacitor, driving the LED beads to emit light. The package includes 3D printed shell files. Compared to the original, this version features the ability to generate electricity in both forward and reverse directions.
n20 motor small flashlight v2 (fix).stl
PDF_n20 Mini Flashlight v2.zip
Altium_n20 motor mini flashlight v2.zip
PADS_n20 Mini Motor Flashlight v2.zip
BOM_n20 Mini Flashlight with Motor v2.xlsx
92437
FP7125 step-down LED driver
This project is a high-power LED driver design based on the FP7125 LED driver chip from Yuanxiang Technology.
The FP7125 is an average current-mode LED driver IC that operates in a constant off-time mode. The FP7125 does not produce peak-to-average current error, thus significantly improving LED current accuracy, line and load regulation without the need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The FP7125 can be powered from 8.0-100V. It provides PWM and linear dimming inputs and accepts external TTL-compatible control signals. The output current can be programmed via an internal 250mV reference.
The shorted pins in the image are for debugging and have been removed in the production project; they do not need to be shorted again.
In this project, the output current is set by adjusting the current sampling resistor U2. The current calculation method is shown in the figure below. This project recommends use below 3A; higher power requires larger inductors and improved heat dissipation.
PDF_FP7125 Buck LED Driver.zip
Altium_FP7125 step-down LED driver.zip
PADS_FP7125 Step-Down LED Driver.zip
BOM_FP7125 Step-Down LED Driver.xlsx
92438
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 05:01:11
