a stacked design. The lower layer houses the car's operation, taillights, low beam headlights, high beam headlights, tracking, obstacle avoidance, and Bluetooth modules.
The upper layer contains the microcontroller. The upper and lower layers are connected by DuPont wires, allowing for the replacement of any microcontroller for customized development.
be supplied via an electric vehicle or a Type-C interface, utilizing the classic IP5306 power management chip.
Screw holes connect to VCC and GND. For convenient connection to upper-level circuitry , an N20 brushed DC
is used to save costs, driven by an RZ7899. Alternatively, an N20 brushed motor with built-in driver functionality can be selected, as it integrates the RZ7899 chip internally.
utilizes four ITR9909 sensors, a dual-channel operational amplifier (XD393) for amplification and comparison.
3 and 4 are connected in parallel with an H11 controller to simulate high beams, while LEDs 5 and 6 are connected in parallel to simulate low beams.
LEDs 1 and 2 are red taillights, requiring pins with PWM functionality; brightness is inversely proportional to acceleration. The default duty cycle is 10% for normal driving and 100% for emergency braking. A buzzer simulates a
; both active and passive modes are possible, but program modifications are required.
The Bluetooth module is connected to the upper-level board using DuPont wires.
Video Link:
[Bilibili Video - Function Demonstration and Introduction] https://www.bilibili.com/video/BV1JRpweWEJr/)
Project Introduction:
This project is a development board based on the STM32F411 microcontroller, with an onboard WCH552GDAPLINK
physical image.
PDF_STM32F411CEU6 Minimal System Board with DAPLINK.zip
Altium_STM32F411CEU6 Minimum System Board with DAPLINK (.zip)
PADS_STM32F411CEU6 comes with a minimum system board for DAPLINK.zip
BOM_STM32F411CEU6 Minimum System Board with Built-in DAPLINK.xlsx
92448
CV numeric keypad
The replica keypad has been modified with changes to the Type-C package, some wiring, and shorting points. The panel now has more backlighting, and the specifications of the copper pillar screws have been adjusted.
Modified from: 3-Key CV Keyboard_Three-Key Engineer Keyboard_CH552G - LCSC Open Source Hardware Platform (oshwhub.com)
. Thanks to the original author.
Modified the Type-C package, modified the programming button, modified the wiring, added LEDs, added keyboard panel backlighting, and adjusted the size of the screws in the same group.
Ignore V2.0, only look at V3.0 and the positioning board. The base plate can be replaced with a V3.0 board for aesthetics.
When soldering the Type-C, be sure to fix it on both sides. If you only solder the four positioning pillars from the back, it is easy to pull them out completely. Always fix it on both sides. The temperature should not be too high, otherwise it will burn the plastic and make soldering more difficult. Other aspects will improve with practice. The original author has already provided a good description, so I won't go into detail here.
The keyboard backlighting uses a copper-pile barrier layer and a solder mask layer, which has an ideal effect and can be clearly seen in the PCB file. The boxes and crosses in the document layer are used to find the center of the circle.
From top to bottom, there are screws, double-through copper pillars, and single-through copper pillar screws. The top plate (positioning plate) is 1 mm thick, and the other plates are 1.6 mm thick. This design securely holds the mechanical key switch in place, preventing it from moving forward, backward, left, or right, while still allowing for easy insertion and removal. This fixation is already very stable. If you want the mechanical key to be firmly secured to the panel, the original design allows for a 1.6 mm thickness, meaning you need to use a 1.6 mm top plate. Additionally, the length of the copper pillars needs to be adjusted to ensure that the distance from the top surface of the central layer to the top surface of the top plate is 5 mm.
WCHISPTool_Setup.exe - Nanjing Qinheng Microelectronics Co., Ltd.
BOM
CH552G
TYPE C Female Socket JLCPCB C2765186
3 x 100nF 0603 Capacitors OR 2 x 100nF 0603 Capacitors and 1 x 10uf 0603 Capacitor
1 x 10k or higher Resistor (optional, as shorting is not required with my method)
3 x Kailh Hot-swappable Switch Sockets
3 x Switches (any 5-pin or 3-pin compatible
) 3 x Keycaps (any keycaps)
2 x 5.1k 0603 Resistors
2 x 1k 0603 Resistors
2 x 0603 LED
Screws are M2, see reference image
PDF_CV Keyboard.zip
Altium_CV keypad.zip
PADS_CV numeric keypad.zip
BOM_CV keyboard.xlsx
92449
STC32G core board
Using STC32G12K128-LQFP64 to build the core board
The STC32G series microcontrollers are 32-bit 8051 microcontrollers that do not require external oscillators or external resets. They are designed for superior anti-interference, ultra-low cost, high speed, and low power consumption. At the same operating frequency, the STC32G series is approximately 70 times faster than the traditional 8051.
They feature an onboard CH340N chip, eliminating the need for an additional programmer.
An onboard AT24C02 chip ensures data retention even after power loss.
Buttons control the MOSFETs to manage power supply, enabling a hard reset and facilitating program downloading.
PDF_STC32G Core Board.zip
Altium_STC32G core board.zip
PADS_STC32G core board.zip
BOM_STC32G Core Board.xlsx
92451
electronic
