K1AyYG4mJ
Interface isolation board for UltraLink
This is an interface isolation board only for UltraLink, and testing has shown it can stably reach 10Mbps. Similar designs can also be used as a reference.
The isolation board only exposes 5V, 3V3, TX, RX, SWDIO, SWCLK, and GND interfaces. The output interfaces use standard ST-TAG interfaces and custom 6-pin sockets (to reduce size).
The isolation chip is the CA-IS3762HN (4 transmit, 2 receive) from Chuantu Microelectronics, and the isolation power supply is the B0503XT-2WR3 from Mornsun. UltraLink provides a separate 3V3 output to power the CA-IS3762HN and a separate 5V output to power the B0503XT-2WR3. The B0503XT-2WR3 has a maximum output current of 600mA and can power the target board. When the target board has an independent power supply, the output can be cut off via a sliding switch.
The attached file is the original AD project.
![a7cfe0f8e47b7aa5e1b3cce03054173.jpg]
MOD_DAP-LINK Interface Isolation Board_H001A.zip
PDF_Interface Isolation Board for UltraLink.zip
Altium Interface Isolation Board for UltraLink.zip
PADS_Interface Isolation Board for UltraLink.zip
BOM_Interface Isolation Board for UltraLink.xlsx
92501
One-to-six power supply boards
One-to-six power distribution board, with signal splitters and terminating resistors.
Project Overview:
This project is a 1-to-6 power distribution board with terminating resistors.
Its functions
include power and signal distribution for robots.
The project
uses a GH1.25*2P connector as the CAN interface and does not require a common ground.
PDF_One-to-Six-Split Circuit Board.zip
Altium 1-to-6 power supply board.zip
PADS_One-to-Six-Split Circuit Board.zip
BOM_One-to-Six-Split Circuit Board.xlsx
92502
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 19:49:58
