dow6L
Wireless network card module for NanoPi Neo3
This is a wireless network card module for NanoPi Neo3, designed based on the Blink BL-8188FU3 module. It uses a USB interface and is powered by 3.3V. An external antenna can be connected via an IPEX connector.
![IMG_20240805_112334.jpg] ![IMG_20240805_112249.jpg] ![1722827970012.png] ![1722827981125.png] ~~Very slow speed and packet loss~~Can be used for SSH.
Regarding the driver:
Use the self-compiled Armbian-unofficial_24.8.0-trunk_Nanopineo3_bookworm_current_6.6.43 image. After initializing the system, clone the [RTL8188FU](https://github.com/i2som/RTL8188FU) project, copy `firmware/rtl8188fufw.bin` from the project directory to the `/lib/firmware/rtlwifi/` directory, and restart the system to use it.
[Mirror Link Download](https://pan.baidu.com/s/1CfjaVG19smlL7qcXEd_qXw?pwd=7ij7)
~~The USB version in the project is unverified!~~
8.25 Update: USB board verified and usable
! ![IMG_20240825_194850.jpg] ![IMG_20240825_194858.jpg] ![IMG_20240825_195013.jpg]
PDF_Wireless Network Adapter Module for NanoPi Neo3.zip
Altium Wireless Network Adapter Module for NanoPi Neo3.zip
PADS Wireless Network Adapter Module for NanoPi Neo3.zip
BOM_Wireless Network Adapter Module for NanoPi Neo3.xlsx
92682
Dong Xiaofeng's voltmeter and ammeter
This project utilizes the LCSC Divinstar development board as its core to achieve high-precision real-time voltage and current measurement. It supports a wide voltage range and USB-C power supply, offering both through-hole and surface-mount versions for flexible selection. All versions feature a 3D housing design, creating an integrated, multi-functional voltage and current meter solution.
Project Overview:
This product is a voltage and current meter designed using the CW32 LCSC Diwenxing development board as its core. It features simultaneous measurement, calibrability, and multiple power supplies.
Project Attributes:
This product is available in through-hole and surface-mount versions. The surface-mount version achieves the same functionality with higher density and features a 3D shell design. It also adds a widely used USB-C interface as a power option to improve usability.
Hardware Part:
Wide Input Module
Through-hole and Surface-mount Versions)
Overall Routing: For both through-hole and surface-mount
versions , it is recommended to start with smaller components and solder the through-hole components last. Note that the USB-C connector is relatively difficult to solder; if your soldering skills are average, it is recommended to omit this function. The overall soldering difficulty of the board is relatively low. Software Part: Keil 5 is used for programming and function implementation. Material Selection Plug-in Version Quantity Comment Designator Footprint Value Manufacturer Part Manufacturer Supplier Part 3 100nF C1,C2,C5 CAP-TH_L5.0-W2.5-P5.00-D1.0 100nF CC1H104MC1FD3F6C10MF Dersonic (DERC) C254085 2 10nF C3,C4 CAP-TH_L4.8-W3.2-P5.08-D1.2 10nF CC1H103ZC1ED3F4D1100 Dersonic (DERC) C2761727 1 100pF C6 CAP-TH_L5.0-W2.5-P5.08-D0.7 100pF CC1H101KC74DSL4B10MN Dersonic (DERC) C254079 2 100nF C7,C8 C0805 100nF CC0805KRX7R9BB104 YAGEO (国巨) C49678 1 ZX-XH2.54-3PZZ CH1 CONN-TH_3P-P2.54_2501S-3P ZX-XH2.54-3PZZ Megastar (兆星) C7429633 2 M3960V-02P CN1,CN2 CONN-TH_2P-P3.96_B4P-VH-B-LF-SN M3960V-02P XFCN (兴飞) C492513 3 1N4148 D1,D2,D3 DO-35_BD2.0-L4.2-P8.20-D0.5-RD 1N4148 LGE (鲁光) C402212 1 1N5819 D4 DO-41_BD2.4-L4.7-P8.70-D0.9-RD 1N5819 LGE (Luguang) C402218 1 DC-005-2.5A-2.0 DC CONN-TH_DC-005-2.5A-2.0 DC-005-2.5A-2.0 XKB Connection (China Xingkun) C319099 2 47uF EC1,EC2 CAP-TH_BD6.3-P2.50-D1.0-FD 47uF KS476M050E07RR0VH2FP0 CX (Chengxing) C45100 1 100uF EC3 CAP-TH_BD6.3-P2.50-D1.0-FD 100uF KS107M016E07RR0VH2FP0 CX (Chengxing) C43805 2 22850120ANG1SYA01 H1,H2 HDR-TH_20P-P2.54-VF 22850120ANG1SYA01 JILN (Jinling) C429947 1 PZ254V-11-04P H3 HDR-TH_4P-P2.54-VM PZ254V-11-04P XFCN (Xingfei) C492403 2 B-2100S02P-A110 JP1,JP2 HDR-TH_2P-P2.54-VM-1 B-2100S02P-A110
Ckmtw (灿科盟)
C124375
KH-6X6X9H-TJ
K1,K2,K3
SW-TH_4P-L6.0-W6.0-P4.50-LS6.5
KH-6X6X9H-TJ
kinghelm (金航标)
C2837519
FJ2381AH
LD1,LD2
LED-SEG-TH_FJ2381AH
FJ2381AH
志浩
C10701
MHL5013URDRT
LD_PWR
LED-TH_BD5.8-P2.54-FD
MHL5013URDRT
MEIHUA (美华)
C417347
XL-502UWC
LED1
LED-TH_BD5.9-P2.54-RD_WHITE
XL-502UWC
XINGLIGHT (Chengxingguang)
C2895480
100mΩ
R0
RES-TH_BD3.5-L9.0-P13.00-D0.5
100mΩ
MF1WS-0Ω1±1%-2T52
VO (Xiangsheng)
C2903206
300Ω
R1,R2,R3,R4,R5,R6
RES-TH_BD2.2-L6.5-P10.50-D0.6
300Ω
MFR0W4F3000A50
UNI-ROYAL (Housheng)
C58609
10kΩ
R7,R10,R12,R15,R16
RES-TH_BD2.3-L6.5-P10.50-D0.5
10kΩ
MF1/4W-10KΩ±1% T
CCO (Qianzhi Electronics)
C119347
220kΩ
R8
220kΩ
MF1/4W-220KΩ±1% T
C119374
1kΩ
R9,R13
1kΩ
MF1/4W-1KΩ±1%T52
Huaxing Electromechanical
C713997
10Ω
R14
10Ω
MFR-25FTE52-10R
YAGEO (Yageo)
C138214
200kΩ
R17
200kΩ
MF1/4W-200KΩ±1% T
C119373
5.1kΩ
R18,R19
R0805
5.1kΩ
0805W8F5101T5E
C27834
10kΩ
RP1,RP2
RES-ADJ-TH_3296W
10kΩ
3296W-1-103-8mm
BOCHEN (Bochen)
C330432
SMD
Quantity
Comment
Designator
Footprint
Value
Manufacturer Part
Supplier Part
100nF
C1,C2,C5
C1206
100nF
FN31X104K500PXG
PSA (Xinchang Ceramics)
C464972
10nF
C3,C4
C1206
10nF
FV31X103K102ECG
PSA (Xinchang Electroceramics)
C394163
100pF
C6
C1206
100pF
FV31N101J202ECG
C382205
47uF
C7,C8
CAP-SMD_BD5.0-L5.3-W5.3-FD
47uF
RVT1E470M0505
HONOR (Honor)
C696191
BX-XH2.54-3PZZ
CH1
CONN-TH_3P-P2.50_BX-XH2.54-3PZZ
BX-XH2.54-3PZZ
Bossie (Bossie)
C18077834
M3960V-02P
CN1,CN2
M3960V-02P
XFCN (Xingfei)
C492513
1N4148
D1,D2,D3
1N4148
LGE (Luguang)
C402212
1N5819
D4
1N5819
LGE (Luguang)
C402218
DC-005-2.5A-2.0
DC1
DC-005-2.5A-2.0
C319099
47uF
EC1,EC2
CAP-SMD_BD6.3-L6.6-W6.6-LS7.2-FD
47uF
VP1H470M0605
HONOR (Honor)
C4054383
100uF
EC3
100uF
RVT1C101M0605
HONOR (Honor)
C37308
BX-PM2.54-1-20PY
H1,H2
HDR-TH_20P-P2.54-VF
BX-PM2.54-1-20PY
Bossie (Bossie)
C18078139
PZ254V-11-04P
H3
HDR-TH_4P-P2.54-VM
PZ254V-11-04P
XFCN (Xingfei)
C492403
B-2100S02P-A110
JP1,JP2
B-2100S02P-A110
Ckmtw (灿科盟)
C124375
HX TS669TP 250gf 009
K1,K2,K3
KEY-SMD_4P-L6.0-W6.0-P4.50-LS9.0
hanxia (韩下)
C5340129
FJ2381AH
LD1,LD2
LED-SEG-TH_FJ2381AH
FJ2381AH
志浩
C10701
XL-502SURD
LD_PWR1
LED-TH_BD5.9-P2.54-RD_RED
XL-502SURD
XINGLIGHT (成兴光)
C2895492
XL-502UWC
LED1
XL-502UWC
C2895480
100mΩ
R0
RES-SMD_L6.4-W3.2
100mΩ
FMF25FPJR100-LH
PSA (Xinchang Electric Ceramics)
C335243
300Ω
R1,R2,R3,R4,R5,R6
R1206
300Ω
1206W4F3000T5E
UNI-ROYAL (Thick Sound)
C17887
10kΩ
R7,R10,R12,R15,R16
R1206
10kΩ
1206W4F1002T5E
C17902
220kΩ
R8
R1206
220kΩ
1206W4F2203T5E
C17956
1kΩ
R9,R13
R1206
1kΩ
1206W4F1001T5E
C4410
10Ω
R14
R1206
10Ω
1206W4F100JT5E
C17903
200kΩ
R17
R1206
200kΩ
1206W4F2003T5E
C17954
5.1kΩ
R20,R21
R1206
5.1kΩ
1206W4F5101T5E
UNI-ROYAL (厚声)
C26033
10kΩ
RP1,RP2
RES-ADJ-TH_3296W
10kΩ
3296W-1-103-8mm
BOCHEN (博晨)
C330432
M3 screws
TP1,TP2,TP3,TP4
M3 screws
SE8550K2-HF
U5
SOT-89-3_L4.5-W2.5-P1.50-LS4.2-BR
SE8550K2-HF
SEAWARD (思旺)
C115012
TL431(0.5%)
U6
TO-92-3_L4.9-W3.7-P1.27-L
TL431(0.5%)
UMW (友台电子)
C351448
HX TYPE-C 6PIN
U7
USB-C-SMD_HX-TYPE-C-6PIN
HX TYPE-C 6PIN
hanxia (韩下)
C18357552
8. Physical verification, voltage measurement.
Simultaneous Voltage and Current Acquisition and Display.zip
WHXY.CW32F030_DFP.1.0.4.pack
PDF_Dong Xiaofeng's Voltage and Current Meters.zip
Altium_Dongxiaofeng's Voltage and Current Meters.zip
PADS_Dong Xiaofeng's Voltage and Current Meters.zip
BOM_Dong Xiaofeng's Voltage and Current Meters.xlsx
92684
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 22:53:14
