zsvpMYvnM
SX1308 Fixed 5V Positive and Negative Voltage Module
The SX1308 fixed 5V positive and negative voltage module allows voltage modification by adjusting resistors R1 and R2. SEPIC boost converter with CUK inverted output.
PDF_SX1308 Fixed 5V Positive and Negative Voltage Module.zip
Altium_SX1308 Fixed 5V Positive and Negative Voltage Module.zip
PADS_SX1308 Fixed 5V Positive and Negative Voltage Module.zip
BOM_SX1308 Fixed 5V Positive and Negative Voltage Module.xlsx
93331
Temperature and humidity detection
It measures temperature, humidity, and battery level, and operates with low power consumption.
The hardware design was inspired by competition videos. The entire development process, from circuit diagram design to PCB layout, followed the learning videos. The software drivers referenced the provided code, while the application was modified to support displaying voltage, temperature, and humidity, and can be woken up by a button. After waking up, the display can be switched between temperature/humidity and battery level via a button. I personally tested it for three or four days, and the battery consumption was normal. Overall power consumption is sufficient for use. Videos are available for reference. The code is attached, but its bug-free nature is not guaranteed. It has been running normally after several days of testing.
VID_20240803_191716.mp4
TH.zip
PDF_Temperature and Humidity Detection.zip
Altium_Temperature and Humidity Detection.zip
PADS_Temperature and Humidity Detection.zip
BOM_Temperature and Humidity Monitoring.xlsx
93332
220V-12V-30W standard power supply
220V-12V-30W standard power supply, dual output
220V-12V-30W standard power supply, dual outputs: one direct output and one fixed 12V or adjustable output. Discussion and guidance are welcome. (Only group: 289917684)
PDF_220V-12V-30W Standard Power Supply.zip
Altium_220V-12V-30W Standard Power Supply.zip
PADS_220V-12V-30W Standard Power Supply.zip
BOM_220V-12V-30W General Power Supply.xlsx
93333
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 19:25:45
