4zaqTD
AT32F413 Permanent Magnet Synchronous Motor Driver Board Sensorless FOC
The sensorless brushless motor drive solution verification board based on AT32F413C8T7
uses a flux linkage observer as its driving method, enabling sensorless closed-loop direct start and
a gate driver with stall protection.
The main control chip is the Peakray FD6288T, and the test motor is the Yateli AT32F413C8T7.
The LA034-040NN07A Hall effect motor (priced at 6 RMB on Taobao) has been tested.
Currently, only the current loop closed-loop has been tested; the Hall input position loop has not been tested.
1.mp4
2.mp4
AT32F413C8T7_FOC.zip
PDF_AT32F413 Permanent Magnet Synchronous Motor Driver Board Sensorless FOC.zip
Altium_AT32F413 Permanent Magnet Synchronous Motor Driver Board Sensorless FOC.zip
PADS_AT32F413 Permanent Magnet Synchronous Motor Driver Board Sensorless FOC.zip
BOM_AT32F413 Permanent Magnet Synchronous Motor Driver Board Sensorless FOC.xlsx
94039
H6_4layer_lpddr3
Allwinner H6 Layer 4, Gigabit/100Mbps
Four-layer, gigabit/100 megabit LPDDR3 DR-ONHD frequency 1056MHz tested successfully, Bluetooth, WiFi, HDMI GPIO. Schematic adapted from Allwinner H6 development board - ARM high-speed circuit design from scratch - JLCPCB EDA open source hardware platform (oshwhub.com)
discussion group: 169300702
PDF_H6_4layer_lpddr3.zip
Altium_H6_4layer_lpddr3.zip
PADS_H6_4layer_lpddr3.zip
BOM_H6_4layer_lpddr3.xlsx
94040
DAPLink-HS_V2.1, upgraded version
DAPLink-HS_V2.1, fully compatible with J-Link-OB-SAM3U128 in both hardware and software.
Function Description:
1. Fully compatible with J-Link-OB-SAM3U128 solution (hardware and software);
2. Supports SWD and JTAG;
3. Supports CDC-URAT;
4. Includes two LED indicators.
Upgrade Summary:
1. Upgrade OB firmware;
2. Restore serial port 2 for backup function;
3. Improve silkscreen indicators;
4. Curved signal lines.
PCB-3D Preview:
DAPLink-HS is recognized in Keil:
Supports USB flash drive drag-and-drop upgrade function.  Firmware update upgrade method:
 Short-circuit TRES and GND to enter maintenance mode; drag or copy the new firmware into or to the virtual disk to complete the upgrade.
DAPLink displays the upgraded J-Link-OB-SAM3U128 test firmware in Device Manager  .
V1 firmware adds power-on time display and USB communication speed display, while V3 firmware additionally supports drag-and-drop programming. OB firmware is for testing debugger functions only and may not be used for commercial purposes. The copyright ultimately belongs to Segger! PCB board making instructions:
  Specify the lamination order   and select the lamination structure
. Note: The Bootloader and Interface firmware have been uploaded in the attachment. First, use another debugger to load the Bootloader firmware, then connect it to the computer's USB port. A virtual disk will be created in My Computer. Then, drag the Interface firmware into it.
firmware_0x80000_J-Link OB-SAM3U128 V1(Changed to 2099-10-30).bin
firmware_0x80000_J-Link OB-SAM3U128 V3(Changed to 2099-10-30).bin
sam3u2c_bl_crc.hex
sam3u2c_if_crc.hex
sam3u2c_mkit_dk_dongle_nrf5x_if_crc.hex
PDF_DAPLink-HS_V2.1, Upgraded Version.zip
Altium_DAPLink-HS_V2.1, upgraded version.zip
PADS_DAPLink-HS_V2.1, Upgraded Version.zip
BOM_DAPLink-HS_V2.1, upgraded version.xlsx
94043
FTHR-G0001 Expansion Board
This project is for the Lingdong Microelectronics FTHR-G0001 expansion board. The expansion board has brought out all the pins of the development board and added functions such as button input, tri-color LED, and ADC input.
User Manual:
This development board supports two download methods: download by clicking the download button in KEIL; or, after connecting to a computer, a USB external hard drive will appear on the computer. Simply copy the hex file generated by the program directly to the external hard drive space to complete the download.
The expansion board has all pins brought out and adds button input, tri-color LED, and ADC input functions. The silkscreen printing on both sides of the pin headers is unclear due to phase inversion. If needed, please disable the phase inversion or increase the font size.
This expansion board has a reserved download section. If the download module is disassembled, please modify the position of the pin headers and their wiring.
There is a problem in the official HAL library example code; the pin settings in the baud rate settings of platform.c are incorrect. PA10 multiplexing function 4 must be changed to PA12 multiplexing function 1. If not modified, the program will download normally, but serial communication will fail, as shown in
the error code (official code) in the image below:
Correct code:
Attachment content description:
DS_MM32G0001_xx.pdf: Chip datasheet
FTHR_G0001_FTYFW.hex: Chip factory program
FTHR_G0001_SCH.pdf: Development board schematic
FTHR-G0001 development board introduction.pdf: Development board introduction
UM_MM32G0001_xx.pdf: Chip user manual
MM32G_PCB&SCH_library.rar: Development board PCB file
Lib_RegSamples_MM32G0001_V2.0.3.rar: Official sample code, including register library and HAL library code
MM32_KEIL_Pack_2.19.rar: KEIL firmware package for MM32
Bilibili link: Lingdong FTHR-G0001 Development Board Unboxing and Partial Function Demonstration_Bilibili_bilibili
DS_MM32G0001_EN.pdf
DS_MM32G0001_SC.pdf
FTHR-G0001_SCH.pdf
FTHR-G0001 Development Board Introduction.pdf
UM_MM32G0001_EN.pdf
UM_MM32G0001_SC.pdf
PDF_FTHR-G0001 Expansion Board.zip
Altium_FTHR-G0001 Expansion Board.zip
PADS_FTHR-G0001 Expansion Board.zip
BOM_FTHR-G0001 Expansion Board.xlsx
94044
SlimeVR_Tracker_32_901S_342
GPL3.0
Hardware implementation of the GPL3.0 SlimeVR Tracker, using the JY901S as the 9-axis sensor and an ESP32 as the main controller. Completed in April 2022. Software solution open source address: https://github.com/Sark1tama/SlimeVR-Tracker-ESP-JY901S
PDF_SlimeVR_Tracker_32_901S_342.zip
Altium_SlimeVR_Tracker_32_901S_342.zip
PADS_SlimeVR_Tracker_32_901S_342.zip
BOM_SlimeVR_Tracker_32_901S_342.xlsx
94045
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 21:20:49
