iwEdf3iLfc
CYT4BB7 microcontroller
I. Schematic Design:
Peripheral Interfaces, Buzzer,
Motor Interface, Encoder Interface
, Buttons, Five-Phase Switch ,
Current Detection
Input Power.
A PMOS fireproof switching power supply is used, regulated by a Zener diode.
Servo
Power Supply: The servo voltage also uses an SCT2450 power chip. Since an SD-7 servo is used, a 20kΩ resistor is used for the feedback ground terminal, allowing for a 6.2V output. Testing showed that the servo exhibits high torque and fast response at 6.2V.
12V to 5V:
The 5V output circuit uses an SCT2450 power chip, characterized by high efficiency, low ripple, and high reliability.
5V to 3.3V and
3V3 op-amp power supply section uses the RT9031-3V3, which is small in size and has low output ripple, making it suitable for designing small circuit boards. II. PCB Design:
Peripheral Power Supply
Core Board. III. Physical Sample.
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 02:15:37
