AcvjcGlw
MM32G0001 Expansion Board
I obtained the MM32G0001 core board from Lingchuang Electronics through the ICEasy platform. Due to its small size and concentrated silkscreen printing, development and learning were not very convenient. I then created this expansion board with
three LEDs, three buttons
, and a power input (1117-3.3V, 5V to 3.3V converter) to ensure stable power supply to external modules.
All GPIOs are sequentially brought out, with a power interface near each I/O port.
Sensors or electronic modules have different power supply voltages, and jumpers are used to select either 5V or 3.3V VCC.
WeChat_20240323200922.mp4
WeChat_20240323200943.mp4
PDF_MM32G0001 Expansion Board.zip
Altium_MM32G0001 Expansion Board.zip
PADS_MM32G0001 Expansion Board.zip
BOM_MM32G0001 Expansion Board.xlsx
95620
Flashing tool for optical modem stick (SFP serial port tool)
Firmware flashing tool for Huawei, ASIC, Nokia and other SFP sticks
Based on [Panda's project](https://oshwhub.com/guocuodecuoguo/shuang-sfp-mao-bang-zhuan-jie-kuo-zhan_copy), I was playing around with it one night out of boredom and noticed that the Type-C port wasn't centered, triggering my OCD. I also took the opportunity to test my half-year-long work on a semi-automatic routing algorithm.
/*March 22, 2024 - Re-ran it using an updated automatic routing algorithm. Only the routing was changed; the component types, quantities, and positions were not adjusted. The previous version's interactive BOM still works.*/
Removed the header pins, replaced the serial port chip with a CH340X, and rearranged the PCB routing. All components were moved to one side for easy soldering with a heating plate. The SFP and Type-C ports were centered, and I even beveled a corner.
In short, here's a comparison with the original project:
![Comparison Image.jpg]
Component standardization is complete; the SFP interface and matching soldering cage can be purchased directly from Taobao.
Verified and successful; serial port content can be printed. The test stick is an Alcatel G-010S-P, shipped about two weeks ago, with a baud rate of 115200, as shown in the image.
![Test Result.png]
The attached file is an interactive BOM exported from AD.
BOM.html
PDF_Optical Modem Flashing Tool (SFP Serial Port Tool).zip
Altium_Optical Modem Flashing Tool (SFP Serial Port Tool).zip
PADS_Optical Modem Flashing Tool (SFP Serial Port Tool).zip
BOM_Optical Modem Flashing Tool (SFP Serial Port Tool).xlsx
95623
[Verified] Kitchen Alarm Clock
One countdown alarm clock
A countdown alarm clock powered by a lithium battery.
Function description:
Left button: Short press to increase minutes, long press to continuously increase minutes
; Middle button: Short press to increase seconds, long press to continuously increase seconds
; Right button: Short press to start or stop, long press to power on/off;
Short press both left and middle buttons together to clear the timeout
state, automatically shutting off after 2 minutes.
Assembly instructions:
The motherboard is secured with screws, the front and back covers are glued together, and the back cover has magnetic adhesive strips.
Accessories:
Lithium battery: Specifications 602040/500mAh, adhesive backing attached to the inside of the back cover, pay attention to the positive and negative
terminals when wiring; Screws: M2.5*5;
Screen: 1.14-inch TFT, 135*240; ST7789V, mine is from Taobao Baoyingfeng Display
. Note: The MCU is AIR32F103CBT6, with 96k RAM enabled, incompatible with STM32F103
           firmware. The casing is included. The firmware can be flashed using ST-LINK, JLINK, or DAPLink.
KitchenClock.hex
Top cover .STL
Bottom .STL
PDF_[Verified] Kitchen Alarm Clock.zip
Altium_[Verified] Kitchen Alarm Clock.zip
PADS_[Verified] Kitchen Alarm Clock.zip
BOM_[Verified]Kitchen Alarm Clock.xlsx
95624
FOC brushless motor driver board F405RG dual-channel
A 2-channel FOC brushless motor driver board based on STM32F405RG, with a size of 10*10 or smaller and a 2-layer architecture.
This is a 2-channel FOC brushless motor driver board based on the STM32F405RG, smaller than 10*10cm. It features a 2-layer
main controller: STM32F405RGT6 (168MHz), 1MB flash memory,
driver IC: FD6288T* 2,
MOS: IRFS3607PBF*12
, op-amps: MCP6024*2 (7.5x amplification), differential
amplifier, sensor interfaces: HALL*2 (UVW), ENCODE*2 (ABZ) completely independent,
screen interfaces: LCD 160*80, OLED 12864, completely independent,
communication interfaces: UART*1, USB*1, for easy debugging or connection to external control units (e.g., Bluetooth serial port).
Project and code: https://github.com/Cuixudong/BLDC_DRV
A star would be greatly appreciated!
March 22.mp4
PDF_FOC Brushless Motor Driver Board F405RG Dual-Channel.zip
Altium_FOC brushless motor driver board F405RG dual-channel.zip
PADS_FOC Brushless Motor Driver Board F405RG Dual Channel.zip
BOM_FOC Brushless Motor Driver Board F405RG Dual Channel.xlsx
95625
[Possibly the most elegant] Zhaoneng M2 painless USB 3.0 installation.
Possibly the most elegant Zhaoneng M2/Hemu AX18 USB 3.0 upgrade solution you've ever seen.
Attention! Strictly prohibited for commercial use!! Playing with it yourself is fine, but selling it is not! A special reminder: I am a heavy user of Xianyu (a second-hand marketplace platform), please don't let me see this on Xianyu or other similar platforms !
A graceful and painless USB patch for the Zhaoneng M2
. Are you still worried about those small 0201 parts? Are you still blinded by flying wires? Are you still uncomfortable with those unsightly flying wires? We don't want that! We want elegance, we want convenience! We want painless! Using JLC's free FPC prototyping, the following patch was created, solving the following pain points: 1. Eliminates manual flying wires 2. Eliminates patching small 0201 parts on the front 3. Eliminates unsightly step-down module patches 4. Comprehensive anti-static protection 5. Calculated impedance matching 6. Perfectly aligned soldering positions – one soldering is all it takes! Finished product image: Step 1: Clean the solder pads and apply a little high-temperature tape to protect them and prevent short circuits. Step 2: Solder the FPC . Step 3: Apply double-sided tape to the back of the FPC. Step 4: Solder the FPC USB connector and connect it to a 12V power supply using a jumper wire. Completed . Insert the USB flash drive. Kernel log displayed: Test:
PDF_[Possibly the most elegant] Zhaoneng M2 painless USB 3.0 installation.zip
Altium_ [Possibly the most elegant] Zhaoneng M2 painless USB 3.0 installation.zip
PADS_【Possibly the most elegant】ZhaoNeng M2 painless USB 3.0 installation.zip
BOM_【Possibly the most elegant】ZhaoNeng M2 painless USB 3.0 installation.xlsx
95627
5.2-inch MIPI In-cell screen with King3399 driver board
5.2-inch in-cell touchscreen for driving
Use a 30-pin reverse ribbon cable to connect directly to the King's DSI port. For Android 13, OpenKylin, and Ubuntu firmware, please join group 290182516 to obtain them, or compile them yourself. The DTS file (for the RK platform) is also mentioned
in the group. By the way , if you can't see the preview image for this 35-inch screen, open it in the editor in the upper right corner.
PDF_5.2-inch MIPI_Incell Screen_King3399 Driver Board.zip
Altium 5.2-inch MIPI In-cell Screen King3399 Driver Board.zip
PADS 5.2-inch MIPI In-cell Screen King3399 Driver Board.zip
BOM_5.2-inch MIPI In-cell Screen_King3399 Driver Board.xlsx
95628
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 14:08:37
