0jkuM0j4e
Air001 Auto Downloader - Switchable Power Version
I referenced Walkline's solution on the open-source platform (https://oshwhub.com/walkline/air001-auto-download-tool)
and modified it to have a switchable power supply, making it convenient for different voltage scenarios.
PDF_Air001 Auto Downloader - Power Switchable Version.zip
Altium_Air001 Auto Downloader - Power Switchable Version.zip
PADS_Air001 Auto Downloader - Power Switchable Version.zip
BOM_Air001 Auto Downloader - Power Switchable Version.xlsx
95658
LCSC Taishanpai Voice Recognition Expansion Board
Voice recognition expansion board for LCSC Taishanpai
The LCSC Taishanpai voice recognition expansion board, based on the Haohaodada ASRPRO4M chip, can be graphically programmed using Tianwen Block software, allowing for quick and easy setup without prior learning.
Please use Tianwen Block for programming, which can be downloaded from https://haohaodada.com/new/resource.php.
Select ASRPRO for the motherboard/device, as shown in the image below.
Then select the example program and
click "compile and download." Note that you should immediately unplug the USB cable after clicking "compile and download." Then select the ASRPRO-4M option, click "burn," and wait for the burning process to complete.
Note: This uses the example program. If you have modified it or are not using the example program, you need to generate a model before downloading.
This step takes 1-3 minutes, requires a stable internet connection, and registration/login.
Now you can enjoy playing with it!
Of course, if you're interested, you can join the group 433214533 to discuss and play together. Mention "LCSC Taishanpai voice recognition" in your message. A 3D-printed speaker cavity shell was added
on March 19, 2024 ; see attachment.
The previous PCB speaker had a low power output, and it distorted at high volumes, so I replaced it with a larger one. The link to the speaker I'm using is here:
[Taobao] https://m.tb.cn/h.5C2s731exol1DvW?tk=W4FMWMScnSr ZH4920 "High-power speaker 36/40MM/3070/4070/3-inch 77MM speaker 4 ohms/8 ohms 2 watts/3 watts/5 watts" Click the link to open it directly, or search for it on Taobao and
select the first result
. The model looks roughly like this:
1b42c760eba6226868185922a5216020.mp4
Horn cavity model.rar
PDF_LCSC Taishanpai Speech Recognition Extension Board.zip
Altium_LCSC Taishanpai Speech Recognition Expansion Board.zip
PADS_LCSC Taishanpai Voice Recognition Expansion Board.zip
BOM_LCSC Taishanpai Voice Recognition Expansion Board.xlsx
95659
51 Minimum System Board
A compact and low-cost 51 minimum system board based on the STC89C52RC chip.
PDF_51 Minimal System Board.zip
Altium_51 Minimal System Board.zip
PADS_51 Minimum System Board.zip
BOM_51 Minimum System Board.xlsx
95660
LCSC ESP32S3R8N8 Expansion Board V1.0
This expansion board is specifically designed for the LCSC ESP32S3 development board and includes features such as USB and lithium battery switching, battery charging, a 0.96-inch OLED screen, stepper motor driver, tri-color LED, digital display, temperature and humidity sensor, photosensitive sensor, rotary encoder, EEPROM, and infrared functionality.
This expansion board is specifically designed for the LCSC ESP32S3 development board and includes features such as USB and lithium battery switching, battery charging, a 0.96-inch OLED screen, stepper motor driver, tri-color LED, digital display, temperature and humidity sensor, photosensitive sensor, rotary encoder, EEPROM, and infrared functionality. The video demonstrates the software power-on/off function, OLED display, and photoresistor ADC voltage reading.
ESP32S3show.mp4
PDF_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
Altium_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
PADS_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
BOM_LCSC ESP32S3R8N8 Expansion Board V1.0.xlsx
95662
FSBox
Speakers that can display the spectrum
The audio data transmitted via Bluetooth is played through an external audio IC, and the audio data is simultaneously subjected to FFT to cut the spectrum and display it on the screen.
f56eb57b8a8b5b51a5f59b912e1d68cb.mp4
614e1746b8a27ebe18e4061010130409.mp4
matrix_led.7z
CAD.7z
PDF_FSBox.zip
Altium_FSBox.zip
PADS_FSBox.zip
95663
Split keyboard almond_cake (no lights)
Based on the RP2040 Pico development board, this small-size, 30% layout split keyboard uses QMK+VIAL and is available with a free prototyping voucher.
The introduction
is a standard brief, but there's not much to say. I used the Vial because it's easy to modify the tap dance and combo keys .
Regarding the layout,
most 30% layouts look similar, basically the QAZ layout. With the addition of tap dance and combo keys, it's perfectly adequate for typing, and the feel isn't too bad.
However, you should think carefully before using it for gaming. I can at least use it for a full-star Abyss run. To save money, I still used the Pico
controller , but the Pico has effectively increased in price. Currently, I'm working on a version using the 52840 chip, a Bluetooth version , and a version with lighting later, but it's just an ambient light; I'm still evaluating whether to place it on the front or side . I didn't draw the outer shell, only the base plate; it's just screws and nuts tightened. Due to the development board... Place it on the back, and you need to tilt the keyboard. You need to put some height-increasing pads on it. I used the anti-collision pads that I posted before. I will put the link in the attachment. You can choose a cheaper one to buy depending on the situation. However, the minimum height is 8mm. Please note that I have prepared two positioning plates. Generally speaking, it is difficult to use the free coupon for the positioning plate. You can use either one depending on the situation. I used a smaller positioning plate for the homepage picture. Of course, DXF will also be provided in the attachment. Other parts (1) This time, you don't need to use color silk screen printing. You can't use color silk screen printing if you want to use the free coupon. (2) Each keyboard has a five-way switch, but I couldn't find a suitable switch cap for it. It's practically useless. So you don't have to solder it when you're using it yourself. I wanted to install the TrackPoint, but unfortunately, I can't use the TrackPoint when running QMK on my RP2040. It throws an error when I compile. (3) To fit the development board, all the switches are rotated 90° or 270°. This may cause some keycaps or switches to get stuck. If this happens, please replace it or just don't use this keyboard. (4) I didn't use low-profile switches this time. I plan to switch to the ZMK solution and then use low-profile switches. One reason is that low-profile switches are really expensive. (5) The keyboard firmware inexplicably misses burning a few keys. The specific reason is unknown. I will try to fix it. (6) As with previous projects, the headphone cable must be four-pole because full-duplex is used. (7) I didn't add RGB because the entire axis rotates 90°, which would make the position of the axis lights look strange and unsightly. Therefore, I didn't add axis light support. Instead, I added soldered axis holes, although it's only for MX axes.
Some material purchase links, for reference only.xlsx
almond_cake.rar
almond_cake universal positioning plate_universal base plate.dxf
almond_cake_vial.uf2
PDF_Almond Cake Split Keyboard (No Lights Version).zip
Altium split keyboard almond cake (no lights) .zip
PADS_Split Keyboard_almond_cake No Light Version.zip
BOM_Almond Cake Split Keyboard (No Lights) xlsx
95664
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 13:17:11
