eNIRQAM
Voron 2.4 Logo Light
[Original open-source link](https://mods.vorondesign.com/detail/3J9JXZNpmvj20VCBslMoag)
requires eight 2020 package WS2812 LEDs.
If you also want LEDs for the nozzle lighting, you'll need two 5050 package SK6812 RGBW LEDs and
two 0402 0.1uf capacitors. Skipping these might prevent it from lighting up.
[Compatible printables are here](https://www.printables.com/model/642714-fysetc-stealthburner-led-carrier-for-neopixel-rain/files)
Thanks to group member WeiQi (1191556802) for helping with testing! [test.png]
PDF_Voron2.4 Logo Light.zip
Altium_Voron2.4 Logo Light.zip
PADS_Voron2.4 Logo Light.zip
BOM_Voron2.4 Logo Light.xlsx
95790
Electric screwdriver forward and reverse rotation circuit (adjustment)
A simple circuit for reversing the positive and negative terminals of an input power supply. It uses only a few simple components, is low-cost, and combines manual and electric operation to achieve its goal: the most perfect circuit is the one that suits your needs!
Although it's a very simple circuit, it's quite functional: one circuit displays the power switch, another is used for charging, and the third allows for reversing the positive and negative terminals. You can assemble it successfully even with your eyes closed, just by following the diagram.
PDF_Electric Screwdriver Forward/Reverse Circuit (Adjustment).zip
Altium_Electric Screwdriver Forward/Reverse Circuit (Adjustment).zip
PADS_Electric Screwdriver Forward/Reverse Circuit (Adjustment).zip
BOM_Electric Screwdriver Forward/Reverse Circuit (Adjustment).xlsx
95791
ESP32-S3-based intelligent voice solution verification board
Verification board based on ESP32-S3 and Espressif speech recognition solution (verified)
Function Overview:
Voice Command Recognition: Recognizes voice wake-up words and command words, and runs predefined function calls.
Speech Synthesis: Voice broadcast of Chinese strings. Voiceprint
Recognition: Identifies the speaker's identity.
Voice Source Direction Recognition: Identifies the direction of the speaker's voice source (lower accuracy).
The main configuration of the verification board is as follows:
WIFI MCU: ESP32-S3, external 16M Flash for storing data and model files required for voice SR and TTS.
Voice ADC/DAC: ES8388.
Voice Amplifier: NS4150B.
MIC Array: Dual analog silicon microphones, spaced 4.0cm apart.
PDF_ESP32-S3-based Intelligent Voice Solution Verification Board.zip
Altium_ESP32-S3-based Intelligent Voice Solution Verification Board.zip
PADS_ESP32-S3-based Intelligent Voice Solution Verification Board.zip
BOM_Intelligent Voice Solution Verification Board Based on ESP32-S3.xlsx
95792
TDA7379 Bluetooth Amplifier
TDA7379 amplifier chip, BT010 Bluetooth, dual-channel amplifier, supports AUX input.
The voltage is 12-18V, only 12V has been tested. There are two indicator lights: PS for power and BT for Bluetooth. The Bluetooth module can be switched on and off. All interfaces use 2.54mm pitch.
PDF_TDA7379 Bluetooth Amplifier.zip
Altium_TDA7379 Bluetooth Amplifier.zip
PADS_TDA7379 Bluetooth Amplifier.zip
BOM_TDA7379 Bluetooth Amplifier.xlsx
95793
RS232485
This is a hardware serial port debugging assistant based on CH340E. It can accept TTL, RS232 and RS485 signals and has been verified to be working correctly.
PDF_RS232485.zip
Altium_RS232485.zip
PADS_RS232485.zip
BOM_RS232485.xlsx
95794
HK32F030MF4P6 Minimum System Board
The HK32F030MF4P6 minimum system board is unremarkable, but its symmetrical layout makes it look nice. The dual-row pin headers have a 5*2.54 hole spacing, leaving three rows of holes on one side when plugged into a breadboard, which is convenient for integration.
PDF_HK32F030MF4P6 Minimum System Board.zip
Altium_HK32F030MF4P6 Minimum System Board.zip
PADS_HK32F030MF4P6 Minimum System Board.zip
BOM_HK32F030MF4P6 Minimum System Board.xlsx
95795
USB to TTL based on CH340N
The CH340N chip is used as the control chip for the USB-to-serial converter. It provides a TTL level serial interface for easy connection to other devices.
The CH340N chip is a USB-to-serial converter chip that converts data from a USB interface into serial data and communicates with other devices via a serial port (TTL level). When a computer sends data via USB, the CH340N converts it into serial data and sends it to the target device through its serial port pins; conversely, it can convert serial data received from the target device into data recognizable by the USB interface and then transmit it to the computer.
PDF_USB to TTL based on CH340N.zip
Altium_USB to TTL based on CH340N.zip
PADS_USB to TTL based on CH340N.zip
BOM_USB to TTL based on CH340N.xlsx
95796
[Training Camp - Instruments & Meters] Replica CW32 Multifunctional Test Pen
This portable multi-functional test pen, based on the CW32F030, features functions such as voltage measurement and threshold judgment, continuity measurement, diode detection, and signal output.
The portable multi-functional test pen based on the CW32F030
encountered many difficulties from schematic design and PCB layout to PCB routing and soldering, but it was finally managed to be replicated with some difficulty.
The functions are consistent with the official examples, including voltage measurement + threshold judgment, continuity measurement, diode detection, and signal output.
The 0805 package surface mount components were all replaced with 0603, as I happened to have them on hand.
(Next time I must make the board larger, like the project for the test brick, otherwise it will be difficult for beginners to lay out, route, and solder. This time I barely managed to do it well.)
The layout and routing were a bit difficult, so I thickened and lengthened the board frame.
Due to a busy academic schedule, and midterm exams in the middle of the project, I really couldn't find the time. I will continue to improve it later.
Acknowledgements
Thank
you to everyone who encouraged me to complete this replication project, thank you to JLCPCB and the CW32 ecosystem community, and thank you to the staff who reviewed it.
PDF_【Training Camp · Instrumentation】Replica CW32 Multifunctional Test Pen.zip
Altium_【Training Camp · Instrumentation】Replica CW32 Multifunctional Test Pen.zip
PADS_【Training Camp · Instrumentation】Replica CW32 Multifunctional Test Pen.zip
BOM_【Training Camp · Instrumentation】Replica CW32 Multifunctional Test Pen.xlsx
95800
LM3915 Music Level Light
Music level indicator based on LM3915, using a microphone to collect sound.
The LM3915 music level light is
a relatively simple circuit that can collect ambient audio and adjust the sensitivity via a potentiometer.
During testing, the potentiometer was not soldered; the input of the LM3915 was directly connected to the output of the op-amp, and a 47k resistor was connected to ground to reduce interference.
This is the effect after lighting up. Personally, I think square LEDs are more suitable than round LEDs for level lights.
PDF_LM3915 Musical Level Light.zip
Altium_LM3915 Music Level Light.zip
PADS_LM3915 Music Level Light.zip
BOM_LM3915 Music Level Light.xlsx
95801
KVM Expansion Board
KVM Expansion Board
Function Overview (Unverified): This feature allows for remote installation of the operating system
via web-based access to the computer's screen output; remote control of the computer's power on and off ; monitoring of critical computer data and alarms . This is an expansion board and requires the V851S Mars board for use.
PDF_KVM Extension Board.zip
Altium_KVM Expansion Board.zip
PADS_KVM Expansion Board.zip
BOM_KVM Expansion Board.xlsx
95802
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 23:45:50
