GemRBw0T0u
IP2326 verification board with 2 series lithium battery balance chargers
IP2326 Features:
15W synchronous switching boost charging
, 94% boost charging efficiency, built-in integrated charging equalization circuit
with power MOS , supports fast charging input request based on battery voltage to improve charging efficiency, constant voltage charging voltage, adjustable external resistor, pin-configurable 2- or 3-series lithium battery charging, adjustable external resistor for automatic fast charging input request based on battery voltage, automatically adjusts input current to adapt to adapter load, supports charging NTC temperature protection , input overvoltage and undervoltage protection with adjustable external resistor, charging timeout protection with adjustable external resistor, supports LED charging status indication , 500KHz switching frequency, supports 2.2uH inductor output, overcurrent, overvoltage, and short circuit protection, IC overtemperature protection, input withstand voltage 25V ESD 4KV 2S, normal lithium battery charging test, normal fast charging trigger, stable operation.
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 02:54:26
