III. Functional Modules
Expansion Board Design Two power inputs: 5V and 3.3V. The 5V input uses a classic Type-C design and a 2-pin connector. The 3.3V input uses a 2-pin connector.
One switch is designed for both 5V and 3.3V, a standard design. Indicator lights are used to indicate the switch status.
Reset and flashing buttons are provided for greater convenience. Flashing can be performed in conjunction with the ESP32 flashing sequence.
Directly connects to the ESP32 flashing board, reflecting a modular approach that reduces costs and increases efficiency.
: The main control module uses the general-purpose ESP32-WROOM-32E, with built-in WIFI and Bluetooth modules. It features a dual-core MCU, ensuring stability and power.
: Three IIC interfaces are reserved to meet simple application scenarios.
: Two SPI interfaces are reserved to meet simple application scenarios.
Sixteen ADC interfaces are brought out, which can also be used as ordinary GPIO.
: Two UART interfaces are brought out, which can also be used as ordinary GPIO.
