ghaytweyhtoo
MAXREFDES143#: Application of DeepCover embedded security in the field of IOT security certification detection and notification
MAXREFDES143# is an Internet of Things (IoT) embedded security reference design that protects industrial detection nodes through security authentication and network server notifications. The hardware includes peripheral modules and mbed platforms: the former serves as a protection sensor node, monitoring the operating temperature and the remaining life of the product (simulated through ambient light detection); the latter serves as a controller node, responsible for monitoring one or more sensor nodes. The design adopts a hierarchical structure. Each controller node collects data from connected sensor nodes and uploads it to the network server. The server is responsible for maintaining central records and necessary scheduling notifications. The mbed platform includes a Wi-Fi module, DS2465 coprocessor with 1-Wire® host function, LCD, LED, and buttons; the protection sensor node includes a DS28E15 security authenticator, DS7505 temperature sensor, and MAX44009 light sensor . The mbed platform communicates with the network server via the onboard Wi-Fi module and with the protected sensor nodes via I2C and 1-Wire interfaces. MAXREFDES143# is equipped with a standard shielded connector and can be quickly tested using mbed circuit boards such as MAX32600MBED#. The simplicity of the design ensures rapid integration into any star IoT network that requires the SHA-256 symmetric key algorithm to provide enhanced security with low overhead.
Please see the Details tab for more information. Design files including schematics, PCB files and bills of materials (BOM) can be downloaded from the Design Resources tab.
Note: MAXREFDES143# programming requires the separate purchase of the MAX32600MBED# development platform or equivalent Arduino specification platform.
characteristic
  • SHA-256 security authentication
  • Each node in the system has a unique key
  • DeepCover® secure key storage
  • 1-Wire/I 2 C/Wi-Fi interface
  • Source code example
  • The pinout of the mbed platform is compatible with Arduino specifications
  • Pmod TM Compatible Protected Sensor Nodes
Competitive Advantage
  • Strong encryption security authentication
  • No secure key memory required on processor
  • Signed data has lower overhead between web server and mbed platform
application
  • Internet of Things (IoT) device node security certification
  • Data security certification at all levels from sensor node to web server
  • Protect industrial applications from counterfeiting
  • Track product lifespan with smart notifications
  • Reject unsafe industrial sensor nodes
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-27 11:09:43
  • Texas Instruments' first integrated ultrasonic T/R switch
  • S3C2440 65x45mm core board circuit diagram
  • Problems encountered in Keil
  • nor flash erase
  • TI C6000 Series Pipeline Concept
  • Regarding some issues with ERC checking in DXP, thank you for your help! ! Urgent~~
