他们逼我做卧底
MAXREFDES37#: IO-LINK four-channel servo driver
The MAXREFDES37# IO-Link ® servo driver provides 5V power, four PWM outputs, and four digital inputs for controlling up to four 5V servo motors. IO-Link can replace pneumatic actuators and their compressed air lines in industrial applications. The addition of a level translator allows the digital input to be connected to a binary position or status sensor . The design creates new applications in the industrial field and creates new traditional pneumatic solutions.
The onboard standard 3-pin header allows quick connection to commonly used 5V servo motors. MAXREFDES37# comes with a HiTec HS-53 servo motor. Plug-in connectors allow easy connection of 5V digital input, power, ground, and operation of all four PWM channels. The reliable externally threaded M12-4 connector allows connection to any IO-Link compatible host. MAXREFDES37# uses TMG TE’s IO-Link device stack. Maxim Integrated recommends using the MAXREFDES79# IO-Link host with a graphical user interface (GUI) program to facilitate verification using a Windows ® PC.
For more information about laboratory measurement data, please refer to the Details tab . Design files including IODD files, schematics, PCB files and bills of materials (BOM) can be downloaded from the Design Resources tab .
characteristic
  • Four 5V PWM outputs
  • Four 5V digital inputs
  • 5V/3.4A servo power supply
  • Compatible with IO-Link version 1.1
  • IEC 61131-9
  • TMG TE device stack
  • Transient voltage suppressor (TVS) diodes meet the following protection requirements:
    IEC 61000-4-2 (ESD)
    IEC 61000-4-4 (EFT)
Competitive Advantage
  • The world's first IO-Link servo driver
  • Four servo drives working simultaneously
  • No more pneumatic air lines required
application
  • control and automation
  • Replace pneumatic drive
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-04 04:20:59
