Light control switch circuit
Source: InternetPublisher:兰博 Keywords: Switch circuit light control switch relay Updated: 2020/04/15
Shown is a light-controlled switch circuit with a simple structure . It works stably and reliably, and is suitable for automatic power supply
control systems for electrical appliances that work at night. IC 1 in the circuit is an operational amplifier UC741C, which is used as a voltage comparator. Its non-inverting input terminal @ pin is adjusted
to obtain a suitable reference voltage by adjusting Rl, and is compared with the voltage on the inverting input terminal ② pin to determine the voltage of its output terminal. level. The voltage on IC 1② pin
is obtained by the series and parallel voltage division of RL, Ri and R2. When there is light, the relay does not work, and when there is no light, the relay operates.
- Analysis of the working principle of car garage door lights
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- One-way rotation circuit of motor controlled by contactor
- Light-controlled circuit design and analysis
- Design and analysis of voice control circuit
- Motorcycle anti-theft device circuit design
- A novel and practical power line anti-theft and cutting alarm circuit
- Delay switch made with LM431
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Use 1 PS3001 light control switch
- Contactless proximity switch circuit 2
- Three-phase zero-voltage switching circuit using CA3058 zero-trigger integrated circuit
- Thyristor AC switch circuit 5a
- One of the light control switch circuits controlled by flashlight
- Light control switch circuit 4 controlled by flashlight
- Simple and practical light control switch circuit
- Light-controlled switch using photosensitive transistor
- Infrared light control switch circuit
