Thyristor power regulation circuit
Source: InternetPublisher:赔钱虎 Keywords: Silicon controlled circuit Updated: 2024/07/04
Working Principle of the Circuit
The schematic diagram of the circuit is shown in Figure 1. The charging and discharging rate of capacitor C1 can be changed by adjusting the gear position of the band switch SA. The AC voltage across C1 is used to trigger the bidirectional thyristor VS to conduct through the bidirectional trigger diode VD3, and the conduction angle of VS is changed, so that the AC voltage across the load RL changes accordingly.
The light-emitting diodes VD2 and VD5 are used as signal indicators. Due to the different conduction angles, the brightness of the light is different. When SA is set to "1", VD5 is displayed; when SA is set to "4", VD2 is displayed; R5 is a current limiting resistor used to protect VS. Resistor R7 and capacitor C2 are an absorption circuit used to absorb the interference pulses generated by SA when selecting gears. Otherwise, it will cause certain interference to televisions, stereos and other electroacoustic devices during the SA gear selection process;
Component Selection
Capacitor C1 is 0.1uF/160V, C2 is 0.022uF/400V (polyester capacitor). Resistor R1 is 56kΩ, 1/2W, R2 is 39kΩ, 1/4W, R3 is 27kΩ, 1/4W, R4 is 2kΩ, 1/4W, R5 is 47Ω, 1/2W, R6 is 100kΩ, 1/2W (variable), R7 is 300Ω, 1/4W, R8 is 43kΩ, 1/2W. Diodes VD1 and VD4 use 1N4004. Light-emitting diode VD2 uses BT104 (yellow), and VD5 uses BT103 (green). Trigger diode VD3 is DB3 or VR60. Bidirectional thyristor V5 uses TLC226B (3A/400V) or TLC336A (3A/600V). The band switch SA uses KZX-1-2D-11W. The load RL is AC 220V/300W (electric furnace wire).
Preparation method and instructions for use
The core device of this circuit is the bidirectional thyristor, so its quality must be tested. Since the circuit is simple, you can design the printed circuit board yourself. As long as the connection is correct according to the diagram, it can work without debugging.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How to identify common mode interference? Methods to eliminate common mode interference
- FPGA Features and Architecture
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the classifications of filters?
- What is power factor and three ways to improve it
- Important things to know about PCB routing and how to design the right routing for your PCB
- How to install the accelerometer
- Star finder battery indicator circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
