Single-phase operation short-circuit braking circuit
Source: InternetPublisher:红水杯 Keywords: Brake circuit winding BSP motor Updated: 2020/10/14
Short-circuit braking is essentially a kind of energy-consuming braking. When
the motor is braking, the stator winding is disconnected from the AC grid, the winding is short-circuited from phase to phase, and the rotor rotates inertly. Due to
the residual magnetism in the rotor, a rotating magnetic field is formed in the rotor and cuts the stator winding, thereby generating an induced electromotive force in the stator winding. Since
the stator winding has been short-circuited, there is an induced current in the stator winding . This current interacts with the rotating magnetic field to generate
braking torque, forcing the rotor to stop. This braking method is only suitable for small-capacity motors below 1.5kW. The short-
circuit braking circuit for one-way operation is shown in Figure 3-153.
- How to use a microcontroller to control a servo motor?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to remotely control devices using ESP8266 and LPC2148
- Peripheral circuit of automotive motor controller power supply chip
- How to build a simple tachometer using an infrared reflectance sensor
- Motor self-starting circuit
- Light-controlled circuit design and analysis
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- PIC microcontroller controlled remote anti-theft alarm circuit
- Ultra-short wave item left behind reminder alarm
- Ultrasonic blind pathfinder circuit
- Farmland drainage automatic control circuit
- Varactor Diode Frequency Modulator
- Simple AGC circuit in transistor radio
- Wien bridge oscillator circuit
- Inductive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- Differential Amplifier Circuit
- Color display circuit
