One of the automatic control circuits that only allows the motor to run in one direction
Source: InternetPublisher:国民男神经 Keywords: Motor BSP power supply Updated: 2021/01/26
90. In some places, the motor is only allowed to run in one designated direction. Even when the power phase sequence
is reversed for some reason (such as incorrect connection after external circuit maintenance), the motor must be guaranteed to run in the designated direction. Otherwise, personal and equipment accidents may occur
. For this purpose, a phase sequence discriminator can be used for control.
The circuit is shown in Figure 3-90. When the phase sequence of the power supply is correct, that is, when the phase sequence is U, V, W, the neon bulb Ne does not light up, the relay
KA is closed, and the start button SBi is pressed, the contactor KMi is closed, and the motor starts running in the forward direction. If the power phase sequence
is wrong, Ne lights up and KA releases. Press the SBi, KMz suction table, change the phase sequence of the motor and then connect it to the power supply . The motor
will still start running in the forward direction.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to make a wheeled self-balancing robot using ultrasonic sensors
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Hydraulic control circuit design and analysis
- Electric vehicle battery charging protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- electromagnetic field sensor
- Pulse therapy circuit
- Farmland drainage automatic control circuit
- Farmland irrigation automatic control circuit a
- Mixer built with analog multipliers
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- base amplitude modulation circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
