Utilize self-induced electromotive force to realize instantaneous protection circuit
Source: InternetPublisher:明天见 Keywords: Protection circuit power supply BSP Updated: 2021/10/30
The circuit is shown in Figure 3-73. This circuit uses the self-induced electromotive force generated by the motor to achieve
instantaneous shutdown protection when the power supply fails instantaneously.
When the power supply fails instantaneously, the contactor KM loses power and is released, the motor
rotates inertly, and the normally closed auxiliary contact of KM is closed.
The self-induced electromotive force between the V and W phases of the motor supplies power to the DC relay KA through the diode VD
. KA is powered on and its normally open contact is closed. If
the power supply is restored at this time, contactor KM is powered on and
locks itself, and the motor is reconnected to the power supply and runs.
- How to use a microcontroller to control a servo motor?
- Analysis of the working principle of car garage door lights
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Tutorial on making your own remote-controlled robotic arm
- An automated model railroad layout project using a microcontroller
- How to set up a cheap beam break sensor control distance scene using a reflector
- Manual automatic air compressor control circuit
- Simple phase failure protection circuit composed of intermediate relay
- Homemade short circuit alarm device
- Bicycle anti-theft alarm
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit b
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Amplitude modulation circuit composed of MC1496
- OTL low frequency power amplifier circuit
- Fault signal trip circuit
