Insulation resistance meter circuit
Source: InternetPublisher:柯南道尔 Keywords: Insulation resistance BSP megger Updated: 2020/08/04
The insulation resistance meter is also called a megohmmeter , and its resistance value is in the megohm level. It is mainly used to measure the insulation resistance of motors and electrical circuits, to determine
whether there is leakage in the equipment or circuit, and whether the insulation is damaged or short-circuited.
The main components of the insulation resistance meter are a magnetoelectric current ratio meter and -/a a hand-operated high-voltage DC generator as the measuring power source. The appearance of the insulation
resistance meter is shown in Figure 5-2a. The insulation resistance meter circuit is as shown in the figure
- How to Measure Turbidity of Liquids Using Arduino
- Analysis of valid and fault conditions of differential signals
- Simple infrared detector
- Inductive Pointer Watch Battery Tester
- A low-cost inductance meter consisting of a single IC
- Design of Multi-point Temperature Measurement System Based on DS18B20
- How to use STM32 to design an alcohol tester
- 1.5V and 9V battery tester circuit diagram
- Geiger counter circuit diagram
- Multimeter DC voltage measurement circuit
- Physiotherapy ventilator circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Domestic KD8041 integrated phase locked loop
- Diode balanced amplitude modulation circuit
- Parallel crystal oscillator
- Power phase sequence display circuit
- Digital stopwatch display circuit
- Sine wave signal generator circuit
