Multi-point control corridor timing light circuit
Source: InternetPublisher:柯南道尔 Keywords: BSP Updated: 2020/02/26
(1) Introduction to circuit principle The circuit is shown in Figure 3-31. The control button switches ANI~AN4 can be installed at different locations in the corridor. As long as
any button among AN1~AN4 is pressed
, the lighting EL will light up immediately. At the same
time, it will be stepped down by the transformer, rectified and filtered, and
power will be supplied to the 555 integrated circuit.
The initial voltage on
the 220tiF capacitor connected to pins ② and @ of the 555 integrated circuit is zero, so
the ③ pin of the 555 integrated circuit outputs a high level, and
the relay Jl actuates, causing the normally open contact Jl-l
to close, and the entire circuit enters a timed self-locking
state. After that, the power supply charges the capacitors on the ② and ⑥ pins of the 555 integrated circuit, and the voltage rises. When the capacitor is charged about 2/3 of the DC power supply voltage,
it is the timing time, which takes about 3 minutes. At this time, the output of pin 3 of the 555 integrated circuit flips to low level, then the pin is released, the contact switch Jl-l is automatically
disconnected, and the light EL extinguished. Just press any button among AN1~AN4 again, and the timer will be reset to turn on the light.
(2) Component parameter selection The selection of components is shown in Figure 3-31, and there are no special requirements.
(3) The multi-point control corridor timing light circuit is shown in Figure 3131.
- A simple magnetic switch circuit sharing
- Controlling LEDs with Node-RED in Raspberry Pi
- DIY an electromagnetic levitation device
- Manual automatic air compressor control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Light-controlled circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Audio interface protection circuit
- Delay switch made with LM431
- Night dog barking anti-theft reminder circuit
- Homemade disinfectant circuit
- Chicken supplementary light to increase egg production rate circuit
- Particle clogging alarm circuit of wheat seeder
- Biogas concentration detection line
- Diode Balanced Mixer Circuit
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Sawtooth wave generator circuit (2)
