Common emitter-common emitter amplifier
Source: InternetPublisher:酷到被通缉 Keywords: Amplifier BSP input resistor Updated: 2020/04/21
It is currently the most commonly used circuit
configuration, as shown in Figure 8-3. It is
composed of two common-emitter circuit couplings with the same characteristics . The coupling form can be resistance-capacitance coupling or direct coupling. Since the input resistance of this circuit is much smaller than the output resistance, the voltage gain of the preamplifier will be reduced by the input resistance
of the subsequent amplifier . Even so, the overall gain obtained
with this configuration of circuit is still the maximum. The total gain of a
multi-stage amplifier is the product of the gains of each stage (if expressed in decibels, it is the sum of decibels).
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What is a D flip-flop and how does it work?
- Simple Wired Spy Bug Circuit Built Based on IC741
- What is the difference between JFET and MOSFET
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- Star finder battery indicator circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Digital number selection machine
- Set timing circuit when power is on
- Egg warming circuit
- Farmland drainage automatic control circuit
- Simple AGC circuit in transistor radio
- Schiller oscillator circuit
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- High and low frequency signal generator circuit
- Power phase sequence display circuit
