Application circuit of TDA1514A
Source: InternetPublisher:张小哥 Keywords: Application circuit A15 BSP Updated: 2021/05/31
It is its typical application circuit . R2 and R3 are feedback circuits. By adjusting their ratio,
the closed-loop gain of the circuit can be adjusted. In order to improve the dynamic range of the circuit, C5, R5, and R form a bootstrap circuit. The startup noise suppression of
TD A15 14A is achieved through capacitor Q. At the moment of power-on, the voltage
across the capacitor C
cannot change suddenly, so one V of the power supply is sent to pin 3 without loss, forcing the silent switch circuit in the circuit to operate, so that the power-on noise
is suppressed. As the capacitor C4 is charged, when the voltage across it rises to a value of V, the voltage at pin 3 drops to 0, forcing the silent switch connected to pin 3
to automatically release, and the amplifier's power amplifier function is normally realized. Resistor R is designed for safe area protection
. Under normal circumstances, the quiescent current of pin 2 is microampere level.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Using TDA2822 to do direct coupler output experiment
- DIY 50W Gallstone Amplifier
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Design and production of NE5532+TDA1521 amplifier
- A simple and practical tube amplifier
- Typical applications of optocouplers in audio amplifier circuits
- Audio power amplifier circuit composed of LM4835/4838
- Horseshoe gallbladder preamplifier circuit
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- Physiotherapy ventilator circuit
- soil content measurement circuit
- Farmland irrigation automatic control circuit b
- TDA1552Q power amplifier circuit diagram
- TDA1516Q power amplifier circuit diagram
- TDA1516BTL power amplifier
- Homemade multimedia active speaker 01
- Power amplifier assembled with TDA1512
- TDA1553Q power amplifier circuit diagram
- Tube amplifier TDA1541 parallel circuit diagram
