FET power amplifier with output transformer 01
Source: InternetPublisher:兰博 Keywords: Power amplifier FET output transformer BSP Updated: 2021/10/14
This article introduces the production of a field effect tube power amplifier with an output transformer. Its tone is very close to
the effect of a tube power amplifier. This circuit is introduced for the reference of audio enthusiasts.
Technical indicators of the power amplifier:
rated output power: 50w (load 8n);
frequency response: 4 0Hz ~ 25Hz flat curve;
harmonic distortion: 0.5‰ (measured at 1kHz);
signal-to-noise ratio: 90d13;
input sensitivity: 800n1V o
The power amplifier is composed of a dual differential amplifier pre-stage and a field effect tube power amplifier stage with an output transformer. The design concept is based
on the principle of "simplicity first".
As can be seen from Figure 7-15, a pair of NPN transistors Vl.v2 constitute the first stage differential amplifier. In addition, a pair of
PNP transistors Vl.v2. Mutodes V3 and V4 constitute the second stage differential amplifier. Two pairs of transistors with different conductivity types improve
the utilization of the power supply voltage, and have different temperature characteristics, which significantly improves the stability of the entire machine. The resistors R5 and R6 in the figure
provide bidirectional AC negative feedback for this circuit, and the circuit is fully complementary and symmetrical, so the DC stability of this circuit is very good, while
the distortion is reduced and the amplitude is very wide. The polarities of the collectors of the front-end output terminals V3 and V4 in the circuit are exactly opposite,
providing two signal sources with opposite waveforms
for the complementary push-pull power amplifier stage.
- Simple and practical EPROM detection circuit
- Temperature Range Monitoring System
- Homemade Metal Detector
- NE555 makes a simple and practical acupoint detector
- TC02 temperature measurement circuit
- Using NE555 to make diode and triode detector
- Multi-speed current test circuit of transistor HFE
- A low-cost inductance meter consisting of a single IC
- Simple password electric lock
- Differential amplifier circuit
- Electronic anti-asthma circuit
- Agricultural temperature control circuit
- Egg heating control circuit
- Farmland irrigation automatic control circuit b
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Inductive feedback oscillator circuit
- Second-order active band-stop filter circuit
- superheterodyne radio circuit
