STK3048A+STK6153 power amplifier circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: Power amplifier circuit ST BSP Updated: 2020/09/19
Motorcycle mainly focuses on the following aspects:
(1) Add a first-stage common source and common base amplifier to the input of ST K30 48A. The idea is to use the input stage of Corus's SAM module
to obtain high transconductance and low noise motherboard
(2). Use the post-stage Darlington tube in ST K615 3 as a voltage stabilizing filter to ensure that the front stage is not affected by large dynamics. Affected by the subsequent stage,
the final stage (3) adopts ultra-large current MOS field effect transistor 2SK851. Judging from the technical indicators, it has large current, small on-resistance,
fast switching speed, low distortion rate, and can drive low-impedance loads. The price is about 23 yuan each, which is equivalent to A13 01/C 3 2 80.
(4) The power supply adopts the switching power supply DNC from Wuhan Tianlong Electronics Research Institute. 3 5 0
(5) adopts current negative feedback and midpoint DC potential servo technology, which not only improves the sense of hearing, but also prevents zero point drift. The actual
measurement is only 5mV per channel 6
(6) Use the fan used in the computer switching power supply to force the heat dissipation of the white circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Simple infrared detector
- Multi-speed current test circuit of transistor HFE
- Temperature-frequency conversion circuit composed of CD4046
- 4-range digital voltmeter circuit using ADD3701
- A low-cost inductance meter consisting of a single IC
- An electronic load meter using LM324 operational amplifier as the main control device
- Production of acoustic and optical digital level detector
- Simple password electric lock
- Typical two-stage low-pass filter circuit
- Agricultural temperature control circuit
- Crop anti-frost circuit
- Agricultural small tractor lighting circuit
- Particle clogging alarm circuit of wheat seeder
- AC voltmeter
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- Power phase sequence display circuit
- Various signal generator circuits
