Four-phase drive circuit
Source: InternetPublisher:spectrum Keywords: Driver circuit FET Updated: 2021/10/07
LS7261/LS7262 can also be used to control
four-phase brushless DC motors . At this time, both CS1 and CS2 are taken
to be . , two orthogonal Hall sensor signals are input from the Sl and S2 pins, and
short-circuit S3 and S2. Figure 3-8 shows a four-phase motor drive connection diagram
using transistors or FETs
, and also
shows current detection and braking control
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Servo motor pin diagram/working principle/application
- Peripheral circuit of automotive motor controller power supply chip
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Simple three-phase motor phase loss protection circuit
- Magnetic door and window anti-theft alarm
- Guanghua brand anti-theft doorbell electronic lock circuit
- "Watchdog" anti-theft alarm circuit
- 13 examples of electric drag control circuit diagram
- Egg heating control circuit
- Multi-channel patrol detection control circuit b
- Electromagnet control circuit
- Negative voltage converter to get -5 to -15V voltage from +5V power supply
- Simple voltage controlled amplifier using junction FETs
- Class A FET amplifier power supply circuit diagram
- Audio AGC circuit using FET
- JFET crystal oscillator circuit diagram
- Glucose-FET working circuit
