30W hybrid amplifier 02
Source: InternetPublisher:常思一二 Keywords: Amplifier SHUNT triode power amplifier Updated: 2020/12/20
The preamplifier and inverter of the amplifier are served by two three- to five-pole transistors 6F2. The pin distribution is shown in Figure 2.9, and the electrical parameters
are shown in Table 2-3. This tube is quite famous, its strength and resolution are higher than 6GH8. Two 6F2 transistors are partially
connected into a single-ended parallel push-pull SRPP (Shunt Regulated Push Pull) circuit to achieve large dynamics, small distortion and low output
impedance. Due to the limitation of "internal force" in the amplifier , the SRPP circuit cannot directly drive the power amplifier . This machine uses the
pentode part of 6F2 to connect into a common cathode differential inverter circuit (often called "long tail inverter
") to supplement the insufficient "internal force" of SRPP. In order to correct and
compensate for the "long tail" cathode Due to the influence of the common resistor, the loads R6 and R7 have different
resistance values (see circuit schematic diagram 2-10). The purpose is to
balance the gains of the upper and lower inverter tubes. The operating point of the SRPP circuit is set in
the linear section of the triode output characteristic (J ≈ 3 mA), and the "long tail" circuit's
I, o ≈ 2.5 mA.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Analysis of the working principle of CMOS/CCD image sensor
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle and truth table of JK flip-flop
- An example of proportional integral circuit diagram
- Color changing flash light principle circuit diagram
- Wireless microphone circuit diagram composed of 9018 triode
- Single supply complementary symmetrical circuit
- Old 20W electronic ballast circuit diagram
- Transistor time relay circuit 2
- Three types of transistor amplification circuits and their characteristics - common emitter circuit
- Interface circuit between power supply coupler and triode b
- One of the water full alarm circuits
- Unijunction transistor wide pulse trigger circuit
- One of the electric contact mercury thermometer constant temperature control circuits
