Hybrid Power Amplifier 01
Source: InternetPublisher:aytwartoofyoroo Keywords: Power amplifier CD4069 CMOS Updated: 2021/07/13
The unit structure of CD4069 is shown in Figure 2-5(a). It is composed of two CMOS FET butt surfaces, and its input-output
characteristics are shown in Figure 2-s(b). Because its unit characteristic is an excellent switching curve, CD406q is often combined into
automatic switches, single spikes or square wave generators for various control circuits, and is rarely used for linear amplification. 6 In fact, Figure 2-5(b) The curve shown is an idealized characteristic, and its actual characteristic curve is shown in Figure 2-5(c). There is a linear area
in its middle area . If
a unit of CD4069 is connected to the amplifier form shown in Figure 2-5 (d), then when the audio signal ei is injected into the input terminal of CD4069
, the amplified high-fidelity signal eo can be obtained at its output terminal.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What does a rectifier do? What is the process of rectification?
- How to identify common mode interference? Methods to eliminate common mode interference
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Working principle and truth table of JK flip-flop
- DIY a decorative lamp
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- What is a Demultiplexer
- Circuit diagram of an example of differential and integral circuits
- Circuit for converting CMOS type BCD code into 7-segment display driver
- Using CMOS to form a time-adjusted spot welding machine circuit a
- TTL and CMOS interface circuit b
- Timing circuit a composed of CMOS 555 (ICM7555)
- TTL to CMOS interface circuit
- Interface circuit between CMOS and transistor
- CMOS to TTL interface circuit
- Using CMOS to form a time-adjusting welding machine circuit-a
- GM3044 type CMOS remote control infrared transmitter circuit
- HTL-CMOS interface circuit
