Simple production of bile and stone mixed power
Source: InternetPublisher:qoistoochee128 Keywords: NI amplifier tube Updated: 2021/11/20
The electrical principle of the hybrid power amplifier is shown in Figure Zl. As can be seen from the figure, the circuit of this machine is simple. The input voltage amplification stage uses the electronic tube
6N11J0. 6N11J is a low-priced fever tube popular among enthusiasts. Its performance is quite good. The voltage gain of the voltage amplifier
is designed to be about 30 times. Its input characteristics The frequency can reach more than several megahertz. The cathode output device uses electronic tube 6 NI J. 6NIJ and
6N11J are equally famous in the audiophile industry. 9 This cathode output device has two functions: First, it uses its high input impedance to reduce the load of the
voltage amplifier , which reduces distortion and obtains The large dynamic output is extremely beneficial; secondly, its low output impedance eliminates
the influence of the input impedance of the VM()S tube on the frequency band, creating favorable conditions for broadening the frequency band of the whole machine. In order to better reduce
the output impedance of the output device, the machine uses a 6 NI J in parallel. When choosing the above two tubes, the first choice is the "Shuguang" brand electronic
tube.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Signal diode arrays/configurations, freewheeling diode operation
- What does a rectifier do? What is the process of rectification?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- RC filter explained in detail
- What is a D flip-flop and how does it work?
- Causes of PCB deformation How to prevent circuit board bending and warping
- Summary of knowledge points of multiplexer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Detection circuit diagram of AC side voltage Us based on SG3525
- Two-channel audio power amplifier circuit diagram analysis
- High-precision low-noise filter circuit design
- Low loss instrumentation amplifier
- Parallel power op amp
- Adjustable output voltage regulator circuit diagram
- Video driver schematic
- variable gain amplifier
- Simple production of bile and stone mixed power
- NICAD Battery Zapper
