60Wx2 linear standard tube amplifier
Source: InternetPublisher:司马缸砸光 Keywords: Amplifier tube BSP Updated: 2020/01/30
The linear standard amplifier follows the traditional circuit structure, and the power tube follows the standard connection method of the beam tube, as shown in Figure 1-8
The output stage power tubes use EL34, KT88, KT100 and other beam tetrodes. The circuit is a Class A and B push-pull amplifier. The early
gate bias circuit is neither completely fixed bias nor cathode bias, but uses a semi-fixed bias. pressure method.
When the output tube uses EI.34 for push-pull amplification, the output power of each channel can be reached. 40W×2;
when using KT88 for push-pull amplification, the output power of each channel can reach 60W×2; when using KT100 for push-pull amplification, the output power of each channel can reach 80wX
2.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What is an ac to dc transformer in circuit design
- This article will tell you the hard requirements of operational amplifiers
- Analysis of the basic principle of measuring resistance by bridge method
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- Transfer characteristics of BJT, how to apply Shockley equation?
- Share a Motorola amplifier circuit
- LED lights that “drain” battery power
- electromagnetic field sensor
- Ultrasonic blind pathfinder circuit
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Rural fish farming control circuit
- DC ammeter
- collector amplitude modulation circuit
- OTL low frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (2)
