Closed loop position servo application circuit
Source: InternetPublisher:念慈菴 Keywords: Application circuit power supply BSP Updated: 2021/05/14
(1) Application in position servo: As shown in Figure 2-26, the control power supply is ±15V.
The driver stage power supply is ±22V. Connect an external H-bridge transistor switch to expand the output current. The motor
drives a potentiometer through gear transmission as actual position detection, and the feedback voltage
is introduced from pin 3. The position command voltage signal is input from pin 4. Use six resistors to divide the voltage to obtain
the peak voltage and threshold voltage of the triangular wave.
- Analysis of the working principle of car garage door lights
- Tutorial on making your own remote-controlled robotic arm
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- DIY an electromagnetic levitation device
- What are the challenges in designing a permanent magnet linear generator?
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Simple phase failure protection circuit composed of intermediate relay
- Home wireless burglar alarm circuit
- Vibration anti-theft alarm circuit
- Motor overcurrent protection circuit
- Ultrasonic blind pathfinder circuit
- Smoking Cessation Circuit
- Rural fish farming control circuit
- Farmland drainage automatic control circuit
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Audio function generator composed of ICL8038
- Schiller oscillator circuit
- Three primary color display circuit
