Gasoline generator excitation module replacement circuit
Source: InternetPublisher:smallembedded Keywords: excitation generator Updated: 2020/12/21
Circuit working principle: Generator stator winding terminal 1 (white) and terminal 2 (yellow) are
voltage detection output lines, which provide the power supply voltage of IC and IC. When
the voltage increases, the conduction of the IC2 optocoupler deepens, the width of the square wave pulse output by IC2 (NE555)
becomes narrower, and the excitation current becomes smaller, thus making the generator output voltage lower. On the contrary, it becomes
higher. Terminals 3 and 4 (blue) provide excitation power, and the actual measurement is AC110 V; terminals 7 and 8
(green/white) are the permanent magnet motor output lines of the engine, providing the excitation current for the generator to start working . Since this circuit uses the field effect transistor IRF350 as the switching output,
the temperature rise is low at full load output.
- Design and selection of electric control valve system drive
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Build a Smart Garage Door Opener Using a Raspberry Pi
- A small improvement to the temperature and water level indicator alarm
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Using P110C to control 6 DC motors simultaneously
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Excitation circuit and synchronous transformer circuit of KZS10 series
- Electromagnetic brake control circuit
- 7kW diesel engine thyristor voltage regulating circuit
- KGLF-31F3 automatic excitation device circuit b
- KL-25 type thyristor automatic excitation device circuit
- Third harmonic excitation circuit
- Overcurrent protection circuit for generator low voltage start b
- Generator longitudinal differential protection circuit a
- Forward and reverse two-phase excitation circuit of four-phase stepper motor
- Two-phase excitation circuit of four-phase stepper motor (forward rotation)
