Make a timer circuit using a time clock
Source: InternetPublisher:偷熊计划 Keywords: timer circuits diodes household appliances Updated: 2020/05/05
Working principle of the circuit: When the time clock reaches the set time,
an AC audio voltage of about 2V is generated at both ends of the speaker. After rectification by the diode and filtering by the capacitor, a DC voltage of about 1V is obtained between the base and emitter of
the transistor VT. , VT is saturated and
turned on, the relay is closed, and the leakage circuit breaker is triggered, thus cutting off the power supply of household appliances
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Servo motor pin diagram/working principle/application
- Design of an autonomous plant watering system using ATtiny85
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- IGBT modules block overcurrent by controlling the gate
- Design and production of wireless multi-location control switch circuit
- Design and production of no-load automatic power-off device for household power supply
- Magnetic door and window anti-theft alarm
- Water supply reminder after water outage
- "Watchdog" anti-theft alarm circuit
- MAX1555 reference design circuit | battery charger application circuit
- Car voice-based mobile phone call reminder
- Photodiode isolation amplifier circuit diagram composed of ISO212P
- Bridge connection of two power op amps
- Object presence and displacement detection circuit
- Lighting light and dark conversion circuit
- Diode IN148 temperature measurement circuit
- Category A and B output circuit using diode coupling
- FM modulator strong-weak signal switching circuit c
- Improved multivibrator circuit c
