Water level automatic controller production circuit
Source: InternetPublisher:已注销 Keywords: automatic controller automatic water level control transistor Updated: 2020/12/13
Circuit working principle: Figure a is the motor control part, Figure b is
the water level detection and electronic switch part. In Figure 1-22b, the transistor VT, resistor Shu,
R: and diode VD. Form a contactless electronic switch. The input terminal of VTl
is connected to the control terminals S, M and D of
the water level detection element, that is, the three electrodes, through the compound contact K of the curse and the DC relay K.
Transistor VTz, resistor R:, capacitor and diode
VD2 form a voltage-dividing amplifier circuit with temperature compensation, which serves as an amplifier stage and
drives the DC relay K. Capacitor C2 and diode VD3 are the release circuit of K. They
absorb the back electromotive force generated when K loses power to protect the transistor VT2. VD4, VDs,
VD. It forms a bridge rectifier circuit with VD7, C2 is the filter capacitor, and T is the transformer. The main circuit
of the motor control circuit is composed of the three-phase knife switch S, the fuse FU,
the main contact of the AC contactor KM and the three-phase asynchronous motor M.
- How to use a microcontroller to control a servo motor?
- The meaning and importance of circuit protection, common types of circuit protection
- Car ice warning circuit sharing
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and principle analysis of practical electric curtain remote control device
- A novel and practical power line anti-theft and cutting alarm circuit
- Ultra-short wave item left behind reminder alarm
- Water supply reminder after water outage
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Photocell trigger control circuit
- time control circuit
- Car window control circuit
- Table printing machine control circuit
- Multi-pole leakage protector circuit b
- Digital current loop control circuit
- Sprinkler control circuit using AC motor
- Micro DC motor steady speed control circuit b
- Temperature measurement and control circuit
