AL3157 low noise charge pump DC conversion application circuit
Source: InternetPublisher:方世玉223 Keywords: Charge pump application circuit low noise DC conversion Updated: 2020/10/15
AL3157 is a low-noise constant frequency charge pump DC/ DC converter that uses dual-mode load switching (1x) and dual (2x) conversion to drive white LEDs. AL3157 can drive 3 LEDs at 30mA and the other LED at 210mA. Flash or LED flash, input voltage 2.7V-5.5V, shutdown current less than 1uA, mainly used in smart torch phone LED backlight, PDA white LED backlight and backlight + torch lighting.
AL3157 Application:
• Smart Touch Phone LED Backlighting
• PDA White LED backlighting
• Backlighting + Torch light
![AL3157 Low Noise Charge Pump DC Conversion<strong>Application Circuit</strong>](http://www.eeworld.com.cn/circuit/upload/af25d1f3e8bd212fb57414ce2db01a16/601ed0b7aeaca08629877972f2e7e773.gif)
Figure 1. AL3157 functional block diagram
![AL3157<strong>Low Noise</strong><strong>Charge Pump</strong><strong>DC Conversion</strong>Application Circuit](http://www.eeworld.com.cn/circuit/upload/af25d1f3e8bd212fb57414ce2db01a16/24ffb9a511fff1cfd2b44cae353f52c5.gif)
Figure 2. AL3157 typical application circuit diagram
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Sharing layout and tips for multi-rail power supply design
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- A very convenient small power supply circuit to share
- Op amp power supply decoupling bypass measures
- LED Driver ZD1680
- Homemade low-power UPS
- Converting a lithium battery charging board into a constant voltage and current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- XTR101 internal functional principle and basic application circuit
- DC output DC converter circuit
- M50197 application circuit
- M5227 application circuit
- AP500 and its application circuit (e)
- STK4036X to 4042X1 typical application circuit
- STKxx series application circuit c
- Application circuit of TDA7294
- AL3157 low noise charge pump DC conversion application circuit
- High-precision AC-DC conversion circuit
