Rimba 458 series induction cooker auxiliary power supply schematic diagram
Source: InternetPublisher:张七岁 Keywords: Power supply schematic diagram induction cooker voltage stabilization Updated: 2021/05/14
AC 220V 50/60Hz voltage is connected to the primary coil of the transformer, and the two secondary windings generate 13.5V and 23V AC voltages respectively. The 13.5V AC voltage is rectified by a bridge rectifier circuit composed of D3~D6 and filtered by C37. In addition to being supplied to the cooling fan, the DC voltage VCC obtained on C37 is also stabilized by the IC 1 three-terminal voltage stabilizing IC and filtered by C38 to generate The +5V voltage is used by the control circuit. The 23V AC voltage is rectified by the bridge rectifier circuit composed of D7~D10 and filtered by C34, and then passes through the series voltage stabilizing filter circuit composed of Q4, R7, ZD1, C35, and C36 to generate +22V voltage for IC 2 and IGBT excitation. circuit use. Rimba 458 series induction cooker auxiliary power supply schematic diagram :
- 1500W PWM based inverter circuit
- Working principle of LDO voltage regulator, basic circuit diagram of LDO
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- What is a battery management system? Analysis of the uses of power management systems
- Schematic diagram of car cigarette lighter to USB power port
- Using Lead-acid Battery as Power Source for Walkman
- Energy-saving motorcycle rectifier regulator
- Switching power supply circuit composition and function introduction of each part
- Voltage-current converter constructed with XTR110
- A small and easy-to-make fast charger
- Power circuit of STR5412
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Industrial four-way programmable controller power circuit
- Household emergency power circuit 02
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- Always ready power circuit
- 5V uninterruptible power supply circuit
- ±5V, ±12V power circuit B
