Differential driver circuit diagram for voltage output DAC AD5620
Source: InternetPublisher:石榴姐 Keywords: voltage output circuit diagram driver DAC Updated: 2020/01/08
The circuit shown in Figure 1 operates from a single +5 V supply and uses the voltage output DAC AD 5620. The input to the DAC is controlled by an SPI port. The DAC's output swings from 0 V to +5 V. The DAC on-chip reference (+2.5 V) is used to set the common-mode voltage of the AD8042 differential driver circuit. This reference has a temperature coefficient of 5 ppm/°C. The output at V? is an inverting DAC output centered on the +2.5 V common-mode voltage. The feedback network and U2-B force the voltage at V+ to be 180° out of phase with the voltage at V?.
Figure 1. Differential driver for voltage output DAC AD 5620
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What does a rectifier do? What is the process of rectification?
- This article will tell you the hard requirements of operational amplifiers
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Basic characteristics/working principles and application circuits of tunnel diodes
- Analysis of three simple electronic dice circuits
- Make a simple AM radio with digital circuit
- A frequency meter circuit diagram composed of CD4046
- Circuit diagram of a voltage doubler rectifier electronic ballast
- Bus stop indicator circuit diagram
- Wireless transmitter principle circuit diagram
- Interface circuit between DAC1210 and 8-bit CPU
- Positive voltage output voltage stabilizing circuit composed of 7900 series
- High voltage output circuit diagram
- Positive and negative voltage output circuit diagram
- Tube amplifier Japanese TDA1541A DAC V2 circuit diagram
- Tube amplifier TDA1541NOS DAC circuit diagram
