Multifunctional CNC waveform generator circuit diagram
Source: InternetPublisher:spectrum Keywords: Generator circuit CNC waveform generator circuit diagram Updated: 2021/01/16
The multifunctional CNC waveform generator circuit is shown in the figure below. It is a practical digital waveform generator circuit that can generate triangle waves and sawtooth waveforms . In the figure, two 4-bit reversible counters SN74L191 are connected in series to form an 8-bit reversible counter. The output of the up or down count is used as the input of the D/A converter, and its output voltage Vo also gradually increases or decreases, changing linearly. When the manual switch S3 is moved to the "2" position, the flip-flop output Q=1, the counter counts down and outputs a negative sawtooth wave; when S3 is moved to the "3" position, Q=0, a positive sawtooth wave is generated; When S3 is moved to the "1" position, Q flips repeatedly between 0 and 1, generating a triangle wave.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- This article will tell you the hard requirements of operational amplifiers
- The Importance and Ideal Model of Impedance Matching
- Types and structures/characteristics/functions/implementations of smart sensors
- Transfer characteristics of BJT, how to apply Shockley equation?
- Build a musical fountain using Arduino and sound sensor
- How to build a triangle wave generator using an op amp and discrete components
- Make a simple AM radio with digital circuit
- LED Night Light
- Voice changing signal generator circuit
- Home appliance repair signal generator circuit
- Several improved sawtooth wave generator circuits - bootstrap circuits with k≥1
- Sawtooth wave generator circuit
- Debugging various signal generator circuits
- Function generator circuit with output oscillation amplitude within 15V range
- Programmable function generator circuit
- Pulse function generator circuit with very large (or very small) duty cycle
- Low voltage DC power supply negative ion generator circuit diagram
- Universal signal generator circuit for radio recorders and televisions
