555 dream lantern control circuit diagram
Source: InternetPublisher:傻阿乐 Keywords: Control circuit diagram lantern control circuit WIDTH Updated: 2021/08/19
Fantasy lanterns with wonderful changes, can be used in shops, dance venues or home holiday decorations. Its control circuit is shown in the figure.
The lantern control circuit consists of a multivibrator, a control circuit, a thyristor trigger circuit and a step-down power supply circuit. The AC step-down rectifier circuitprovides +9V DC voltage to IC 1 and IC2. IC2 uses YX9010, a dedicated integrated circuit for lantern control, which has eight lantern control modes in its chip memory. The peripheral circuit of this integrated block is very simple. It can be controlled manually or automatically. AN is a manual switch. Each time it is pressed, the color light display scheme changes once, which can realize all four color lights, fast and slow forward flash cycle, fast and slow backward cycle flash, and forward and backward switching flash, etc.
ck="window.open(this.src)" alt="Click to see larger image" />
SA is the automatic mode switch. Connect it to the output pin 3 of IC1 (closed) to realize automatic conversion and control of the colored lights. IC1 (555) and R1, RP1, R2, C1, etc. form a multivibrator. Its oscillation period T=0.693 (R1+2R2+RP1) C1
The oscillation period given by the parameters in the figure is 5 to 76 seconds, and the duty cycle is close to 1:1. The multivibrator pulse output by IC1 is added to pin 13 of the control mode conversion terminal of IC2. Each time it comes to a high level, it is specially used for lanterns. The outputs A, B, C, and D of IC 2 change state once. As the astable circuit continues to flip, the flash patterns and colors of the lanterns also continue to flip, changing over and over again, creating a dreamy effect. The thyristor in the circuit can be selected according to the power of the load lantern. 3CTS-1A, 3CTS-3A, SCTS-5A, etc. can be used, and its reverse breakdown voltage should not be lower than 400V (Class D). Triac.
- Signal diode arrays/configurations, freewheeling diode operation
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- FPGA Features and Architecture
- RC filter explained in detail
- What are the parts of the fpga design process
- Beautiful crown wreath made with LED
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How does RCCB work?
- How to build a triangle wave generator using an op amp and discrete components
- LA4185 power amplifier circuit diagram
- AN7178 power amplifier circuit diagram
- AN7149N power amplifier circuit diagram
- MJE13005×2 electronic ballast circuit diagram
- Constant voltage current limiting charger circuit diagram
- Ultrasonic transmitting circuit composed of discrete components
- Blind multimeter circuit diagram
- 5V-USB charger circuit diagram
- Automatic telephone call recording circuit
- Simple signal generator for signal tracing
