555 neon light high frequency and high voltage source circuit diagram
Source: InternetPublisher:无人共我 Keywords: Circuit diagram neon lights high frequency and high voltage Updated: 2021/03/15
This power supply is composed of a time base circuit 555 as the core, and the circuit is as shown in the figure. 555 and R1, R2, C2, etc. form a multivibrator with an oscillation frequency of f=1.44/(R1+2R2)C2
The oscillation frequency of the parameters shown in the figure is 17.8kHz, and the duty cycle of the output pulse is close to 1:1.555. After the output is cut by D3 and other bottoms, it drives the high-frequency amplifier VT1. Due to the access of the base D3 and LED1, the amplifier It works in Category C status. C5 is used to prevent the occurrence of reverse peak voltage and protect the transistor VT1. The secondary of the amplifier transformer can output a high-frequency voltage of about 12500V, which can be used to drive a 3-6m long neon lamp to ignite and glow. VT1 uses high-power tube 3DK308A or BU406, its electrical parameters are 7A/400V/60W, ft is not less than 6MHz.
ck="window.open(this.src)" alt="Click to see larger image"/>
- How to identify common mode interference? Methods to eliminate common mode interference
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Causes and solutions for noise in digital Class D amplifiers
- How to calculate the value of capacitors in parallel?
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED lights that “drain” battery power
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- A frequency meter circuit diagram composed of CD4046
- Simple level conversion circuit diagram
- Cycle timer circuit diagram with start and stop preset functions
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Motorcycle ignition circuit diagram
- Household small TV transmitter circuit diagram
- Pressure measurement circuit diagram
- Zero-crossing trigger circuit diagram based on thyristor
- JB35 module external circuit diagram
- Expanded principle circuit diagram of secondary circuit of high-voltage line
