555 monostable circuit used as capacitance meter or resistance meter circuit diagram
Source: InternetPublisher:newrudeman Keywords: Circuit diagram Updated: 2020/04/14
As shown in the figure, a pointer type capacitance meter can be formed by using 555, timing resistors R1~R3 and the capacitance to be measured Cx. The principle of measuring capacitance in a monostable circuit is to use the larger the capacity of Cx, the larger the temporary pulse width of the monostable state. , that is, the longer it takes for the voltage on Cx to charge to the threshold level (2/3Vdd). Due to the existence of the relationship td=1.1RCx, when a fixed period input pulse is triggered, the average amplitude of the output terminal is proportional to td (or Cx). Use an ammeter to detect its amplitude, and the current flowing through the meter head The size reflects the size of the output pulse width td of 555, which reflects the capacity of Cx.
ck="window.open(this.src)" alt="Click to see larger image" />
If Cx in the circuit is replaced by a fixed capacitor C, and the measured resistance Rx is placed at the position of R, it can be used as a resistance measurement meter by changing the range switch and recalibrating the meter . Figure b is its waveform diagram.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- This article will tell you the hard requirements of operational amplifiers
- Analysis of the basic principle of measuring resistance by bridge method
- The Importance and Ideal Model of Impedance Matching
- How to read resistor color codes? Resistor color codes illustrated
- FPGA Features and Architecture
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Ceramic filter structure/working principle/characteristics/application
- LED Bicycle Lights
- Voice controlled flash LED light circuit diagram
- Cycle timer circuit diagram with start and stop preset functions
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Electronic frostbite treatment device circuit diagram
- Long-distance FM transmitter circuit diagram made of high-frequency triode
- Fingerprint identification system circuit diagram based on FPGA
- Pressure measurement circuit diagram
- Internal functional block diagram of reset chip TLC77XX
- Four bedrooms and two living rooms circuit diagram
- Battery discharge protector circuit diagram
