555 simple electronic massager circuit diagram
Source: InternetPublisher:清宁时光 Keywords: Massager circuit diagram Updated: 2020/04/24
The circuit is composed of a 555 oscillator and a power amplifier driver stage as shown in the figure.
555 and R1, R2, RP1, C1, etc. form a multivibrator. Its frequency can be adjusted through RP1, that is, f=1.44/(R1+R2+RP1) C1. The frequency range given by the parameters in the figure is 2~106Hz .
The low-frequency pulse output by 555 is inverted and added to the input end of IC 2 through VT1, and is driven by power amplification to pulse transformer T. Its secondary CZ socket is connected to the metal plate electrode of the massager to massage or care for the strained parts of the human body. The LED emits indicator light in synchronization with the oscillation frequency. RP1 is used to adjust the frequency, RP2 adjusts the massage intensity; SA uses a spiral potentiometer with a switch.
ck="window.open(this.src)" alt="Click to see larger image" //>
- The unidirectional conduction current of the diode, the diode and its common uses
- What is an ac to dc transformer in circuit design
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- The Importance and Ideal Model of Impedance Matching
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Why use PWM? What are its advantages?
- What is the difference between JFET and MOSFET
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- How to learn circuit diagrams?
- Voice controlled flash LED light circuit diagram
- 220V welding machine wiring circuit diagram
- Unbalanced current drying motor winding circuit diagram
- SCA demodulator circuit diagram
- LM3914 drives 20 LED light-emitting columns circuit diagram
- Circuit diagram of wireless ECG monitoring system based on GPRS
- Fingerprint identification system circuit diagram based on FPGA
- Car battery charging circuit diagram
- An accurate current monitor circuit diagram
