Zero type rectifier and voltage stabilizing circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Rectifier circuit diagram voltage stabilizing circuit Updated: 2021/01/11
The voltage regulator tube of this circuit is connected in front of capacitors and resistors. The voltage regulator tube is connected to the AC power supply through the input capacitor in its conduction direction, and limits the current in the blocking direction to recharge the connected capacitor , thereby stabilizing the output voltage. The voltage ripple of this circuit is larger than that of the bridge type, but because it is directly connected to the AC power supply, the current consumption is smaller.
ck="window.open(this.src)" alt="Click to see larger image" />
- Driving circuit of switching power supply field effect tube
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- ISO113 circuit that can reduce power consumption
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Transformerless AC-DC constant current LED driver circuit
- Power supply circuit that can reduce LM317 ripple
- 3~15V 10A adjustable voltage regulated power supply
- Car power 1.5V-12V six-speed converter
- Adjustable voltage regulated power supply circuit
- MAX1811 Lithium Battery Charger Production
- Design of adjustable DC stabilized power supply circuit module
- Excellent performance household inverter power supply circuit
- Power supply circuit design optimized for digital light projectors
- Output 12V-10A power supply circuit
- Single-phase silicon rectifier DC welding machine no-load automatic stop circuit
- Application of TCA785 in single-phase semi-controlled rectification system
- Three-phase semi-rectifier energy consumption braking circuit of electric motor
- New refrigerator controller circuit
- Zero type rectifier and voltage stabilizing circuit diagram
- 10x voltage rectifier circuit
